4-finger Lever Blade
Reinis.
I found the 4 finger lever blade to be MUCH better than the standard blade, more comfortable and more power, only thing it would be a little more spongey due to the extra length, but i stuck a 2 bolt booster on my frame and it solved that, after running a vee, which has mega hold i would say that the magura with a 2 bolt booster and a 4 finger lever has equaled the vee! and it has more bite which is a bonus!
Adam
Adam
^ his brake is uber stiff and rather good :)
Im using an RB lever which has the same sort of leverage as the 4 finger and the brake is pretty spongey but I have a very flexy (titanium) frame and a tiny small booster. Get one but just be prepared to put a 2bolt booster on if youre not running one now.
