gu trials Posted September 26, 2008 Report Share Posted September 26, 2008 both of my inserts on my chris king have threded and the bolts were still loose has any body else had this problem ?? Quote Link to comment Share on other sites More sharing options...
BenLeacock™ Posted September 26, 2008 Report Share Posted September 26, 2008 You need to take more time and be careful with your threads, you've recently fucekd your magura ones haven't you ? New axel will be needed i'd of thought ! Never had any problems with my king ? Quote Link to comment Share on other sites More sharing options...
JonMack Posted September 26, 2008 Report Share Posted September 26, 2008 Echoing what Ben said, you really should take care of your threads a little more and not rush tightening bolts up. Quote Link to comment Share on other sites More sharing options...
gu trials Posted September 27, 2008 Author Report Share Posted September 27, 2008 its not the axel itsself its the little inserts inside it.. Quote Link to comment Share on other sites More sharing options...
..::littlesam::.. Posted September 28, 2008 Report Share Posted September 28, 2008 both of my inserts on my chris king have threded and the bolts were still loose has any body else had this problem ?? don't you mean stripped? if its threaded then its fine as it comes threaded (sorry but i had to correct him) yer all i can say is what others have said be careful with your threads and it sounds like your going to need to get a new Axel. Sam X Quote Link to comment Share on other sites More sharing options...
Reinis. Posted September 28, 2008 Report Share Posted September 28, 2008 If you have vertical dropouts, maybe you could try the quick-release? Quote Link to comment Share on other sites More sharing options...
eskimo Posted September 28, 2008 Report Share Posted September 28, 2008 If you have vertical dropouts, maybe you could try the quick-release?I would of thought they have different axles so the weight isn't on the actually quick release. Quote Link to comment Share on other sites More sharing options...
