Revolver Posted September 24, 2008 Report Share Posted September 24, 2008 Bleed it in the bath.You can watch it to see when the air has finished coming out, and so when the bleed is finished. Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted September 25, 2008 Author Report Share Posted September 25, 2008 (edited) Bled it with what little blood I had. Works amazing! Best it has ever worked. Got my own special grind ( mechanical engraver on every square inch of sidewall) and 44 Tango pads = absolutely sick! But I didn't make it to my demo. Oh well, I guess that's what I get. Edited September 25, 2008 by J Trials 31 Quote Link to comment Share on other sites More sharing options...
j-bonham@hotmail.com Posted September 25, 2008 Report Share Posted September 25, 2008 mecanical engraver... you got a pic of your rim finished ? woule be interested to see it cheers, john Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted September 25, 2008 Author Report Share Posted September 25, 2008 (edited) Nah, don't have any pics, but I might think about taking some updated pics and putting them in the Bike pics section.How the crap do you have the name John Bonham? Famous Led Zeppelin drummer if you didn't know. I always knew he was still alive!! Edited September 25, 2008 by J Trials 31 Quote Link to comment Share on other sites More sharing options...
RobinJI Posted September 25, 2008 Report Share Posted September 25, 2008 DOT 3 and 4 are glycogen based. DOT 5 is silicone based. They are completely different. They use DOT 5 in Hope brakes, so why wouldn't it work in Maguras? Seals should be no problem with the silicone base.Fish can breath underwater so I should be able to.steel doesn't dissolve in costic soda, so neither will my face, think I'll go apple bobbing with a twist.Because they're not the same maybe?Hope breaks use dot 4 or dot 5.1 fluid. They're bled with dot 4 as standard though, and dot 5.1 is Glycogen based just like dot 3 and 4.Put dot 3/4/5.1 fluid in a break designed for mineral oil, and it'll eat the seals, put mineral oil in a break designed for Dot and the seals will swell.I wouldn't be able to say if dot 5 would work, I know it works in systems designed for other dot fluids however, so I would take an educated guess that it wouldn't. (This is not to say Dot 5 is compatible with the other Dot fluids, the system would need completely flushing before hand and all the previous fluid replacing with dot 5)So yeah, Hopes can be used with dot 5, but I dunno about maggies. Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 25, 2008 Report Share Posted September 25, 2008 I'm still disappointed no-one made a seal killing/Canadian joke. Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted September 25, 2008 Author Report Share Posted September 25, 2008 Doesn't matter now anyway mate. Got it bled with leftover blood. Quote Link to comment Share on other sites More sharing options...
forteh Posted September 26, 2008 Report Share Posted September 26, 2008 This is not to say Dot 5 is compatible with the other Dot fluids, the system would need completely flushing before hand and all the previous fluid replacing with dot 5IIRC Dot5 is silicone based and much more susceptible to water absorption, it has a much higher boiling point though so is used more on the race track Quote Link to comment Share on other sites More sharing options...
tom aky Posted September 26, 2008 Report Share Posted September 26, 2008 Waters useless itll corrode it use magura oil. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted September 26, 2008 Report Share Posted September 26, 2008 90% of trials riders that run magura brakes use a water bleedIt's fineScrapping the fluid altogether, however, takes things to another level Quote Link to comment Share on other sites More sharing options...
Token Posted September 26, 2008 Report Share Posted September 26, 2008 I use cooking oil, feals exactly same as maggie blood but costs £0.75 for 2 litres.Where can I get your cooking oil for 75p for 2 litres? I run my van on it and have never found it for as cheap as that! Quote Link to comment Share on other sites More sharing options...
Skoze Posted September 26, 2008 Report Share Posted September 26, 2008 Scrapping the fluid altogether, however, takes things to another level You kids and your vee brakes! Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted September 26, 2008 Report Share Posted September 26, 2008 Only playing - a well set up maggie can be just as sweet as a vee Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted September 26, 2008 Report Share Posted September 26, 2008 Only playing - a well set up maggie can be just as sweet as a veeand usually is... Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 27, 2008 Report Share Posted September 27, 2008 Waters useless itll corrode it use magura oil.No. No, it doesn't. Even using a strong antifreeze and water solution doesn't 'corrode' 'it', whatever the 'it' is that you're refering to. Piston? Seals? Springs? Either way, it's bollocks and it doesn't. Quote Link to comment Share on other sites More sharing options...
