Jimmy_c Posted September 22, 2008 Report Share Posted September 22, 2008 Right trying to find out what spokes length i need. Ive used the search and found how to work it out using a spoke length calculator etc. But now iam stuck, iam not sure how to read the table that it showsI have a hope pro 2 rear hub and a try-all rear rim (47mm wide) The ERD of the rim is 542,Could some please have a look http://www.wheelpro.co.uk/spokecalc/thanksJames Quote Link to comment Share on other sites More sharing options...
JonMack Posted September 22, 2008 Report Share Posted September 22, 2008 Well it's simple really. R = Radial, 1x = 1 cross, 2x = 2 cross, etc.As it's a rear wheel, I'd suggest 3x, so non drive side = 258.6 and driveside = 257.9. They'll probably be rounded to 258 on both sides.(I put that the rim/hub are 36h, if they're 32, then will be 262's both sides. Quote Link to comment Share on other sites More sharing options...
Exstionhead Posted September 22, 2008 Report Share Posted September 22, 2008 Right trying to find out what spokes length i need. Ive used the search and found how to work it out using a spoke length calculator etc. But now iam stuck, iam not sure how to read the table that it showsI have a hope pro 2 rear hub and a try-all rear rim (47mm wide) The ERD of the rim is 542,Could some please have a look http://www.wheelpro.co.uk/spokecalc/thanksJamesa normaly get all my spoke lenghts from dt swiss 262 both side for the normal pro 2 135mm262 drive side 263 disc side on the pro 2 trialsThey both 3 cross hope that helps you out m8 Quote Link to comment Share on other sites More sharing options...
Jimmy_c Posted September 22, 2008 Author Report Share Posted September 22, 2008 a normaly get all my spoke lenghts from dt swiss 262 both side for the normal pro 2 135mm262 drive side 263 disc side on the pro 2 trialsThey both 3 cross hope that helps you out m8Super thanks for that! James Quote Link to comment Share on other sites More sharing options...
