Whats Up With My Frame ?
gu trials
when i first got my gu le one of the magura mounts threded and it got taped and then was ok and then i stripped the one above it to move the cylinder in and it threded so i helicoiled them all. and today i changed from a 4botlt booster to a 2bolt booster and now three of mounts work but the top left hand side one keeps f****ng up the heli coils and it has been helicoiled 3 times :S:S
i tried using the two bolts which came with the booster but they keep hitting the bottom of the frame and hanging out so i am using cut down bolts so it fits.
please help
please help
have you inserted them?
cause if you have get some longer inserts cause the smaller ones a wank like!
danny
heres a few thing o try.
Take achain apart the small cicrullar rings that are inbetween links are the perfect sized spacers just need a few of them.
And also i had this hppen to me, i went to a local mototrbike secialist to get mine done and he explained that if you are using steel (bolts) and alu frame or visa versa they have a small reaction which causes the threads to weaken and thus strip but if you use copper grease which is like £4.50 from halfords it helps to prevent the reaction by causing a small barrier and protecting the threads..
Tom
Edited by ToMhIlL131
Tom
my dads one of the top motobike specialists round here he does all mine :D when you next come to kendal matt we will take it down to my dads!
