irvinegr Posted September 19, 2008 Report Share Posted September 19, 2008 (edited) Hey. so i was adjusting my hs33 brakes from the spinny thing on the lever, then i hit the limit(i spun it all the way), then the part that pushes(that looks like this ------*, fell off the threads of the spinny part. so i just took off the lever part only, and fixed the spinny thing that adjusts the breaks,. then i out the lever back on the hs33, and i lost all pressure. so now its like there is no fluid in my breaks. just wanna know whats going on here.lol I hope you can under stand what i am talking about. if you miss understand you will think i am totally stupid.edit, when i say that i took off the lever i took this part off.______________________________________________________________________________________________________________________________________EDIT EDIT_______________________________________-ohh k, i was just reading this http://www.biketrial.ch/pages/bike-tech/ma...05_griff_en.phpand when you take off the lever it says to hold the piston down... i didnt and i guess it came out, then after i fixed the lever i just pushed it back in...how would i fix this?? do i need to just bleed the breaks?? Edited September 19, 2008 by irvinegr Quote Link to comment Share on other sites More sharing options...
Smoby Posted September 19, 2008 Report Share Posted September 19, 2008 your a very confusing man . Craig. Quote Link to comment Share on other sites More sharing options...
JamieWilliams Posted September 19, 2008 Report Share Posted September 19, 2008 (edited) Just bleed it and it should be OK.JamieWhat do you bleed it with?, if you use water then just put the lever in water undo the bleed bolt and pres in until there are no bubbles. watch this http://www.trials-forum.co.uk/forum/index....ails&id=484 Edited September 19, 2008 by Jamie L L williams Quote Link to comment Share on other sites More sharing options...
billy_deacon:) Posted September 19, 2008 Report Share Posted September 19, 2008 (edited) The same has happened to my hs33 and i dont no how to fix mine Edited September 19, 2008 by billy_deacon:) Quote Link to comment Share on other sites More sharing options...
G-baby158 Posted September 19, 2008 Report Share Posted September 19, 2008 Just bleed it and it should be OK.JamieWhat do you bleed it with?, if you use water then just put the lever in water undo the bleed bolt and pres in until there are no bubbles. watch this http://www.trials-forum.co.uk/forum/index....ails&id=484Thats a dengura, can you do the same with a magura then ? Quote Link to comment Share on other sites More sharing options...
billy_deacon:) Posted September 19, 2008 Report Share Posted September 19, 2008 Does no one no how to fix it ? Quote Link to comment Share on other sites More sharing options...
billy_deacon:) Posted September 19, 2008 Report Share Posted September 19, 2008 right i just fixed mine its working fine now What i did was brought a new TPA, i brought this one http://www.tartybikes.co.uk/product.php?pr...p;category_id=5then when you have your new TPA on you have to re-bleed your brake and get all the air bubbles out and thats what i did to mine and its fine now.So try giving that a go billy Quote Link to comment Share on other sites More sharing options...
G-baby158 Posted September 19, 2008 Report Share Posted September 19, 2008 right i just fixed mine its working fine now What i did was brought a new TPA, i brought this one http://www.tartybikes.co.uk/product.php?pr...p;category_id=5then when you have your new TPA on you have to re-bleed your brake and get all the air bubbles out and thats what i did to mine and its fine now.So try giving that a go billyIf the TPA isnt stripped/ broken why buy a new one if you dont need to ? All it sounds like it needs is a rebleed. Quote Link to comment Share on other sites More sharing options...
irvinegr Posted September 19, 2008 Author Report Share Posted September 19, 2008 If the TPA isnt stripped/ broken why buy a new one if you dont need to ? All it sounds like it needs is a rebleed.yeah for real, i'll rebleed it. thanks guys.ps. how long does it take to become a member? i've been here for a while now. Quote Link to comment Share on other sites More sharing options...
G-baby158 Posted September 20, 2008 Report Share Posted September 20, 2008 yeah for real, i'll rebleed it. thanks guys.ps. how long does it take to become a member? i've been here for a while now.As long as it does, cant say how long its when the admins/ mods think you can be validated. Quote Link to comment Share on other sites More sharing options...
