TrialsMan Dan Posted September 16, 2008 Report Share Posted September 16, 2008 I have a bit of a habit tapping onto my front wheel to get up obstacles. I often use a hook-up or zap-tap to get up something but always use my front wheel first. can anyone give me advice for tapping straight onto the rear wheel as its kinda annoying me...Dan Quote Link to comment Share on other sites More sharing options...
JonMack Posted September 16, 2008 Report Share Posted September 16, 2008 I suggest you read this thread, http://www.trials-forum.co.uk/forum/index....howtopic=125268 Quote Link to comment Share on other sites More sharing options...
Greetings Posted September 16, 2008 Report Share Posted September 16, 2008 TRA made a guide which should have been turned into a sticky. Too tired to search for it though.If you've got your technique right but can't hold the bike on the rear wheel, I suggest you just use less speed, don't lean forwards so much when you're doing the tap and try to pull the bike up and ahead of you, not up and under.Another thing might be not to hit the front wheel too low. If the walls are under say 40", try hitting them hard on the edge. Quote Link to comment Share on other sites More sharing options...
