mista-neos Posted September 12, 2008 Report Share Posted September 12, 2008 Hi there i was just wondering why people use front freewheel. On the bike im using its just causing problems e.g. snaped 3 chains, jamed once and just shreaded a tooth from the rear sprocket. So does any one elce have any problems with theres and what are the good points about front freewheel.Thanks Blake Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted September 12, 2008 Report Share Posted September 12, 2008 Takes some of the weight away from the back end. Doesn't put so much pressure on the hub. Generally have more EPs. Quote Link to comment Share on other sites More sharing options...
Czar-rider Posted September 12, 2008 Report Share Posted September 12, 2008 Only problem is they eat your pants haha but other than that most people cant afford to buy Profile & King hubsbut freewheels do the job! Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted September 12, 2008 Report Share Posted September 12, 2008 it has many advantages ,e.g the engage feels a bit quicker,weight moved to the middle,cheaper to buy,easier to service,you can change gear without pedaling etc.some of the disadvantages are chain wear is slightly worse and occasionally your trouser get stuck in the chain.i found that correctly installing chains stop them snapping ,what chain are you using mate?steve Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 12, 2008 Report Share Posted September 12, 2008 If you're riding mod, then the chain wear won't change much at all, as you're still running 18:12 (Or whatever ratio you've got on there...). The chain does spin all the time, but it's under very little tension if you aren't actually pedalling, so it won't wear it out much at all. Quote Link to comment Share on other sites More sharing options...
trialin Posted September 12, 2008 Report Share Posted September 12, 2008 something I can sure about is.....front freewheel design actually transfer the weight forward to buttom backet from rear huband it makes your rear felt lighter Quote Link to comment Share on other sites More sharing options...
mista-neos Posted September 12, 2008 Author Report Share Posted September 12, 2008 Ok so if its set up properly its good. Steve i have snaped a KMC kool,KHE callapse and a half link BMX chain.Thanks again Blake Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 12, 2008 Report Share Posted September 12, 2008 Half-link chains are shit, so no surprise. Same goes for Collapse chains. How old was your Kool when you broke it? Quote Link to comment Share on other sites More sharing options...
trialin Posted September 12, 2008 Report Share Posted September 12, 2008 Half-link chains are shit, so no surprise. Same goes for Collapse chains. How old was your Kool when you broke it?really!?I haven't tried half link chain, looks nice Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted September 12, 2008 Report Share Posted September 12, 2008 it mus be how the chain is put together,a crappy chain lie or isn't maintained properly like e.g oiled and clean Quote Link to comment Share on other sites More sharing options...
mista-neos Posted September 12, 2008 Author Report Share Posted September 12, 2008 The kool was on the bike when i got it but it did have some rust here and there and the KHE and half link were new from the shop lol. Quote Link to comment Share on other sites More sharing options...
George ZHI Posted September 12, 2008 Report Share Posted September 12, 2008 Yes! Freewheels all the way! They are great in many ways as mentioned before but they do EAT YOUR TROUSERS. george Quote Link to comment Share on other sites More sharing options...
