Perfect Chainstay Length?
aener
I'm thinking of getting a marinobike frame made, and thought that it'd be nice not to have to run a tentioner.
I've seen a few people without tentioners, on stocks, so I was just wondering if anyone knew how long the chainstays on whatever frame it is are, and what gear ratio they were running.
Ideally, I'd like to run 22:18, but 18:15 would be Ok too.
If I'm wrong, and no-one's got that - could one of the mechanics/engineers on here have a crack at figuring it out?
I'd do it myself - but I don't really know how :$
Cheers (Y)
As soon as the chain stretches you'd end up needing a tensioner anyway!
Get horizontal dropouts, and ask him about the dropout design (onza use it now) which is a bolt that pushes the wheel back. I know he can do that, because I asked him. :P
Nope Ciguenas have horizontal dropouts. :P
It's a nice idea, but if your going to be playing around with gear ratios then horizontal dropouts are best, I'm running 16:13 and I get quite a lot of chain slap, but I can't get another link out of the chain. I've got my tensioner set really really tight aswell, so I think I'll just have to wait until my chain stretches, then get a link out. I've got a KHE Collapse though, so waiting for it to stretch might not work.
I think you will need some method of adjusting/tensioing the chain.
For a while on my Echo pure I had a chain that fitted with no need for a tensioner, then I fitted a new chain and new cranks (still same gears) and it no longer fitted perfectly. I had to go back to using a tensioner.
my zenith ( 18-16 ) with a k910 chain, 375mm stays has to have a tensioner :ermm:
Yeah that's my point exactly. I'm now running 18:16 on horizontal dropouts and the chainstays are bang on 375mm. The chain is really tight too. Either way, even 0,5mm will make a big difference here because that length is doubled when it comes to chain length.
precisely...theres no ideal cs length
ive your LUCKY you can get a frame with vertical dropouts where you not need tensioner, but when you put on chain it will
ALOT too tight , and after 1 week it will be ALOT too slack and you need to change chain.
Having a KHE chain does not help . I have tried .
Go for a vertical dropout with 385 chainstay and put a tensioner on it.
Alot of people have done aswell as i have, building your own special tensioner which does
not use they mech hanger , as the mech hanger is really almost the only downside by
having one .
