Crank Brothers Iodine C Problem
esfrost
Okay heres the story:
I bought a Crank Brothers Iodine C directset a couple of days ago. Everything went pretty well during the installation. After i installed erverything and tightened up the bolts, i discovered that the hs starts to get sticky when i starts turning the bar. I also feel the wobble, but only when im turning the bar. I cant feel it, if i just pull the front brake while moving the bike back and forth. I took everything apart two times, just to check it again, but i couldnt find the problem. I dont see anything wrong with the hs.
Anyone any ideas?
