Aaron.Tottman Posted September 9, 2008 Report Share Posted September 9, 2008 hey,i decided to run a Mavic D521 because i kept going though single wall rims like theres no tomorrow but it's only like 27mm wide and suffer from traction probles and the tyre rebounding too much, i let it down that little bit and i start pinching tubes.another reson i run theD521 is the wieght it's only bout 450g.i've been running this front wheel for nerly a year and a half and decided for a change.anyone know ofa double wall rim 35-42mm that would take a beating that done wiegh a tonelooking at echo (what i use for the rear) but it's nearly 300g heavyer than the mavic!!!any ideascheers AaRoN Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted September 9, 2008 Report Share Posted September 9, 2008 (edited) drilled dx32?reggie/ronnie? Edited September 9, 2008 by Grant-Hundley Quote Link to comment Share on other sites More sharing options...
psycholist Posted September 9, 2008 Report Share Posted September 9, 2008 (edited) There's an EX729 from Mavic now as well - its 29mm wide rather than the 21mm (Internal width) for the D521. Possibly worth looking at if you like Mavics. If Mavic started making rims in the 40mm width territory they'd make an absolute killing... Edited September 9, 2008 by psycholist Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 9, 2008 Report Share Posted September 9, 2008 looking at echo (what i use for the rear) but it's nearly 300g heavyer than the mavic!!!Said it before, I'll say it again: Strong/Light/Cheap - pick two. Or, in fairness, one, in this case But seriously - if you want a wider, strong front rim, it's obviously going to weigh more than the D521 'cos there's almost half an inch of extra rim width there? If you want a stronger, wider front wheel, then just accept it's going to be heavier, or just keep running what you've got now? You can't make a rim wider and be double-walled without there being more material, and therefore more overall weight. Quote Link to comment Share on other sites More sharing options...
Bigman Posted September 9, 2008 Report Share Posted September 9, 2008 Perhaps an Onza Reggie, They are double walled and last very well, even when the holes get drilled out bigger (Prawn did this) slightly wider than a D521 at 32mm, worth a look i recons.Adam Quote Link to comment Share on other sites More sharing options...
forteh Posted September 9, 2008 Report Share Posted September 9, 2008 If Mavic started making rims in the 40mm width territory they'd make an absolute killing...Too right, I run d521s on my santacruz and theyre still going strong 10 years on, never needed tensioning or truing. Running an xc517 on the front of my trials bike, very light and plenty stong enough for my riding, I try not to be a basher though The quality of mavic rims is far superior compared to ANY trials rim currently out. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 10, 2008 Report Share Posted September 10, 2008 ive got a 729 if anyones interested, disk only 32 hole, 26" Quote Link to comment Share on other sites More sharing options...
Aaron.Tottman Posted September 10, 2008 Author Report Share Posted September 10, 2008 Said it before, I'll say it again: Strong/Light/Cheap - pick two. Or, in fairness, one, in this case But seriously - if you want a wider, strong front rim, it's obviously going to weigh more than the D521 'cos there's almost half an inch of extra rim width there? If you want a stronger, wider front wheel, then just accept it's going to be heavier, or just keep running what you've got now? You can't make a rim wider and be double-walled without there being more material, and therefore more overall weight.i can can exept that more metal means more weight!!!?!?not asking for anything that nessaseraly stronger (in comparison i dout that i could find something stronger unless i went for HALO Combats or something) just what would be a decent alturnitive for trials use!!!don't get me wrong i loved using try-all's front rim but went through 2 of them in about 6weeks.OnZa ronnie's temping but only one colour (i used a hog on the rear for a while.) alex DX32 only come in 36hole. after 32 (I should of said really.)chances are i'll go for echo just to suit what i got on the rear.Dose/has anyone used the Revell rims????single-wall but they look quite strong?or can any one recomend a single wall that'll take street riding?like i say i'm only using the mavic due to weight over strenth, but the reason why i want to change is performance for trials (ie...front wheel moves/landings.)thanks for all your replys.AaRoN Quote Link to comment Share on other sites More sharing options...
eskimo Posted September 10, 2008 Report Share Posted September 10, 2008 Have you tried a different tyre and/or pressure? Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted September 10, 2008 Report Share Posted September 10, 2008 if your coming to worcester friday, i can bring my reggie rim if you want itgive me a fiver for it and ill be happy Quote Link to comment Share on other sites More sharing options...
Guest Posted September 10, 2008 Report Share Posted September 10, 2008 Two rims in 6 weeks?What are you doing to them? Quote Link to comment Share on other sites More sharing options...
eskimo Posted September 10, 2008 Report Share Posted September 10, 2008 Two rims in 6 weeks?What are you doing to them?They fold oh soo easily if enough tension isn't kept. I never had problems with my 28h one though. Quote Link to comment Share on other sites More sharing options...
JonMack Posted September 10, 2008 Report Share Posted September 10, 2008 Who's building your wheels Quote Link to comment Share on other sites More sharing options...
Aaron.Tottman Posted September 12, 2008 Author Report Share Posted September 12, 2008 (edited) Two rims in 6 weeks?What are you doing to them?turning off blunts BMXy moves.Who's building your wheels Super cyles for the first one.Single track bikes for the second.i build my own now.Have you tried a different tyre and/or pressure? Tioga xcmaxxis advantageand ona Try-all at the mo.when it comes to tyre pressure i hate when the tyre folds over the side of the rim throws me off. used to ride BMX so like harder prssures. 15-25 depending on weather. rear 5psi harder than front. Edited September 12, 2008 by Aaron.gloster Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted September 16, 2008 Report Share Posted September 16, 2008 Your a hard man to please.id say Alex dx32 for the win. drilled for weight saving and wide to stop tyre roll.Or just live with what youve got. 521s are mint and with a hard run tryall tyre that set up should be fine. Quote Link to comment Share on other sites More sharing options...
