New Products From Heatsinkbikes.com
Heatsink
What about running a 4 bolt booster under the brake adapters?
That's what Ali was saying before - the V-brakes pivot "around" the tube. Think of it like them trying to push themselves around the outside of the tube, rather than trying to flex the tube out. As a result, having the booster lower to the frame means it doesn't really stop flex as much as it does if it's above the brake.
Steve, I'm trying to figure out the extra mount position... On the top one, the 4 bolt mount would line up with the 3 bottom holes on the adapters... But if you mounted it on the lower hole on the adapter, where would you bolt the bottom of it?
I'm probably being stupid (tired!) but I can't see it? :huh:
It goes under the pivot. :P
