Help With Hs33's
bigamac
i use cable v-brake rear and disc on front
my mate has hydrolics i presume hs33
he said he has put to much pressure on the fluid
in turn the brakes wont let go of the wheel
it doesn't work by lowering pressure
well i dont think he can turn it down
what does he need to do?
another mate of mine thinks he has to bleed brakes
to much fluid
i kinda agree
help please?
Try water bleeding it, it's supposed to be better than using fluid
Question: How can you put too much pressure on the fluid
if the pads don't let go of the wheel they are pushed in to far and will be rubbing against the rim, which will ware down the pad
Edit: do you mean the tpa is stuck and the lever is not responding very quick or it is too stiff
Edited by Czartrials
Sounds like the pistons have seized. Try taking them off and put some oil onto the outside of the piston where the pad clips on and let it sit for a little while. Then, put the pad only the floor and press down on top of the cylinder, with your foot if you have to. Once it's back in (if it goes in) re-bleed the break (bath tub bleed will do) and pump the lever while putting more oil on the outside of the piston, you'll probably have to push it back in by hand a few times.
