tmks88 Posted September 2, 2008 Report Share Posted September 2, 2008 (edited) has anyone had any experience with Viz splined sprockets? are they good? or do they wear out fast like cheap cassette sprockets, im worried about 7075 alu on the viz sprocket, most of the sprockets are made from cro-mo so im afrait that viz sprocket wont last for a long time (3+ chains/6+ months)i would buy a surly or BT sprocket but if VIZ is good then ill buy it because i can get them much faster Edited September 2, 2008 by tmks88 Quote Link to comment Share on other sites More sharing options...
Skoze Posted September 2, 2008 Report Share Posted September 2, 2008 Will you be using it as part of a singlespeed setup? (from memory) They are quite thin compared to some sprockets on the market, so you might have a bit of a problem with them digging into the hubshell, i'm currently using a BT sprocket and it's awesome! The base is so wide, doesn't dig in at all.With most modern trials sprockets, i highly doubt that they'll wear very fast at all, no matter what it is Quote Link to comment Share on other sites More sharing options...
tmks88 Posted September 2, 2008 Author Report Share Posted September 2, 2008 theyre wide enough http://trialbikes.ru/items/14/s_singlespeedkit.jpg Quote Link to comment Share on other sites More sharing options...
Skoze Posted September 2, 2008 Report Share Posted September 2, 2008 They'll be fine then I had one once and can't remember it all that well! Quote Link to comment Share on other sites More sharing options...
