onza-t-pro-boi Posted September 1, 2008 Report Share Posted September 1, 2008 what is better on the rear Hope Mono Trial '08 or hope tarty trial thanks harry Quote Link to comment Share on other sites More sharing options...
Aaron.Tottman Posted September 1, 2008 Report Share Posted September 1, 2008 what is better on the rear Hope Mono Trial '08 or hope tarty trial thanks harry if you got the money and don't fall of much go for tarty's but there aint much difference appart from weight.i met martyn ashton over the week end and he was saying that he'd use the mono over a magy on the rear!?!i used to use a shimano XT four pot on the rear and i feel more comfident ona well setup magy??? Quote Link to comment Share on other sites More sharing options...
Muel Posted September 1, 2008 Report Share Posted September 1, 2008 The only difference is the colour, the lever blade and the TI bolts, (I think). I'd say they are definately worth it, I've got carbon blades and they are absolutely brilliant, much more comfy than the 06 or 07/08 levers.I'd also say it desn't matter if you fall off a lot, the newer 07/08 lever blades bend pretty easily, I'd be surprised if you managed to snap the carbon lever blades, they are carbon fibre after all. I've got a Mono Trial on the rear of my mod and my stock, they work brilliantly, you can't compare them to an XT, XTs were designed for XC, so they need to give lots of modulation and power, but bite and hold doesn't really matter. Quote Link to comment Share on other sites More sharing options...
Aaron.Tottman Posted September 1, 2008 Report Share Posted September 1, 2008 Fair shout on the shimano stuff.my mono trials 06 i think...snapped just after the pivot bolt on the lever!!!!to be fair though it took a f**kin beating before hand!!! Quote Link to comment Share on other sites More sharing options...
Jake Beach Posted September 1, 2008 Report Share Posted September 1, 2008 They are both the same I think except from the tarty one is black and has tartybikes etched onto it. Quote Link to comment Share on other sites More sharing options...
javzi monty Posted September 2, 2008 Report Share Posted September 2, 2008 what is better on the rear Hope Mono Trial '08 or hope tarty trialthere the exact same dont get a hope get a avid bb7 much more powerful as hopes go all spongey Quote Link to comment Share on other sites More sharing options...
austen Posted September 2, 2008 Report Share Posted September 2, 2008 there the exact same dont get a hope get a avid bb7 much more powerful as hopes go all spongeyNo. Hopes go "all spongey" when its time for a re - bleed like every other hydrolic brake on the market, and i've heard that bb7's work amazing on the front but are pretty poor on the back. So defenetly don't listen to him saying there much more powerful, when in reality there not at all.As For your question there the eact same part from the small things that Muel said.Austen x Quote Link to comment Share on other sites More sharing options...
Muel Posted September 2, 2008 Report Share Posted September 2, 2008 there the exact same dont get a hope get a avid bb7 much more powerful as hopes go all spongeyHopes "go all spongey" when they have been set up incorrectly, to get the beast out of them they need the mounts facing and need to be shimmed out perfectly.They generally shouldn't need rebleeding because any bubbles that are in the system will slowly rise through the system when you ride the bike, unless there is a leak at the bottom.I've never used a BB7 with the bite or holding power of a well set up Hope, but they seem like the best alternative to me.Have you thought about a Magura Louise? My brothers has a lot more hold than any of my Hopes, but it's a 180mm rotor on a Mod. The downside for me is that it feels really wooden at the lever, and has almost no modulation at all, so on the rear it should be amazing. Quote Link to comment Share on other sites More sharing options...
