Mod Spacing Hub With Gears?
J Trials 31
But seriously, what I said just then...
EDIT: Thinking about it, if the smallest sprocket was 14t on that, if you ran a 21-22t sprocket all the other gear ratios would be easier, so it'd be defeating the point of it. So if that biggest sprocket is 18t, you'd need to run a 27t sprocket to have the normal ratio.
Twenty
Seven
Tooth.
BMXers use what? If you mean 27t sprockets then yeah, they do, but bearing in mind how much a lot of trials riders shit themselves if they haven't managed to scrape out enough grammes of metal from the front of their headtubes, I'm guessing a BMX sprocket and the required cranks would probably not go down too well, not to mention all that extra chain weight, the derailleur weight, etc...
