George ZHI Posted August 30, 2008 Report Share Posted August 30, 2008 Hey! At the moment im hooking slightly slanted walls, just above waist hight. If theres any advice i could get on getting my hooks higher, more powerfull or maybe to vertical walls. Thanks guys, george x Quote Link to comment Share on other sites More sharing options...
Ashley-Wood Posted August 30, 2008 Report Share Posted August 30, 2008 (edited) as i said today riding with you, try and go fast and have more of a kick so you can get your back wheel higher up the wall! also make sure soon as your front wheel is on top of wall put all your force to the front end and go right over!and go at a slight angle this also helps!im not an expert so i might be wrong anyway haaa Edited August 30, 2008 by Gu-Triials Quote Link to comment Share on other sites More sharing options...
George ZHI Posted August 30, 2008 Author Report Share Posted August 30, 2008 Alrite ill see if i can tomorow at the castle! I know what you mean about a harded kick but its just getting the height on the kick. Thanks x Quote Link to comment Share on other sites More sharing options...
mrBENN Posted August 30, 2008 Report Share Posted August 30, 2008 Hi I say the best way to learn is to watch videos and things and see how they do them and then just give it a go Quote Link to comment Share on other sites More sharing options...
George ZHI Posted August 30, 2008 Author Report Share Posted August 30, 2008 Yer will do mate, ill try find a tutorial or something. Cheers Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted August 30, 2008 Report Share Posted August 30, 2008 First off is speed, you need a good amount of momentum going into the wall to get you up the wall, as with backwheeling or any other move in trials (of course, the momentum you create must be used accordingly with technique).The main aim when hooking is getting your weight over the front end of the bike when in hook position, to physically lever your bike up.The technique that I managed to grasp is to hit the wall with lots of weight over the front (on steeper walls going at an angle so you bad foot ends up close to the wall is good, again look at videos and you will see this natural angle in most cases), then once in hook position, immediately use your momentum to endo the rest of the bike up, and then from here just land it or switch it.TrashZen has some good pictures and animations for references.http://www.trashzen.com/wheel-hook-front.phpNow get sorted and practice. Quote Link to comment Share on other sites More sharing options...
George ZHI Posted August 31, 2008 Author Report Share Posted August 31, 2008 Thanks, really helpfull information, the pictures on trashzen are great to. Thanks mate. George. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted August 31, 2008 Report Share Posted August 31, 2008 You're hooking waist height walls?Anyway, as has ben said the quicker you hit it, the better chance you have of translating that into upward motion and getting yourself ontop of the wall. Quote Link to comment Share on other sites More sharing options...
Ashley-Wood Posted September 1, 2008 Report Share Posted September 1, 2008 N.Wood said: You're hooking waist height walls? im pretty sure you do bigger than that george no point in hooking otherwise you could roll up it ha Quote Link to comment Share on other sites More sharing options...
George ZHI Posted September 1, 2008 Author Report Share Posted September 1, 2008 Yer haha i couldnt really think of an approprite hight to say on here lol x Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted September 2, 2008 Report Share Posted September 2, 2008 jump higher Quote Link to comment Share on other sites More sharing options...
