langey Posted August 30, 2008 Report Share Posted August 30, 2008 hi there i just brought a magura service kit and i was wonderin how to bleed the brakes.thanks Quote Link to comment Share on other sites More sharing options...
Kieran24 Posted August 30, 2008 Report Share Posted August 30, 2008 http://www.trials-forum.co.uk/wiki/Bleeding_Magura_brakes Quote Link to comment Share on other sites More sharing options...
langey Posted August 30, 2008 Author Report Share Posted August 30, 2008 thanks for that.. Quote Link to comment Share on other sites More sharing options...
Aarron on a echo lite 08 Posted August 30, 2008 Report Share Posted August 30, 2008 Hello, if you take of the two allen keys bolts and get the bleeding tube and push it out unitl water comes out the other one and what you using water or oil? if oil only one bolt, Hoped i helped, Aaron. Quote Link to comment Share on other sites More sharing options...
Kieran24 Posted August 30, 2008 Report Share Posted August 30, 2008 Hello, if you take of the two allen keys bolts and get the bleeding tube and push it out unitl water comes out the other one and what you using water or oil? if oil only one bolt, Hoped i helped, Aaron.Not quite sure what you mean, but whether you are doing a water or oil bleed you always undo both bleed bolts on the lever and slave cylinder. Quote Link to comment Share on other sites More sharing options...
Revolver Posted August 30, 2008 Report Share Posted August 30, 2008 You want to open both bolts, QUICKLY put the tubes on each bleeding port, then you push the oil through.The absolute best way imo for oil bleeds is using two syringes. If you put a tiny bit of fluid in one syringe, and enough to do a complete brake and a bit more in the other, you can push/pull the oil all the way through. Then when fresh oil starts coming into the syringe with the old oil in, it will have fresh oil in and no air. You can watch the air come out in the syringes too. Quote Link to comment Share on other sites More sharing options...
