Looking For A Bike.
xXxBradd3rsxXx
T-Pro's are a popular choice as the frame geo is good, same as the 05 koxx. But you can build up with the frame and make it into a very nice bike which rides ace. The thing is with T-pros, the standard parts arent really good. But you could pick one up cheap and then spend some more cash just building it up a little. Like putting new bar and stem on, new forks, amd possibly new wheels and cranks. You could easily make it into a tidy starting bike.
Smithy x
Smithy x
Ok thank you mate
brad x
yabba 649 £499 of tarty but it has a full try-all build on it an amazing starter bike for the price heres the link http://www.tartybikes.co.uk/product.php?pr...;category_id=10
comes with and facts about it
Complete Yaabaa bike, a sub-brand of Koxx/K-124, with a great spec for the price.
- Full 6061-T6 aluminium alloy frame with bashplate and head tube reinforcement and dedicated 4-Bolt Magura HS33 mounts.
- Tough steel forks with dedicated 4-Bolt Magura HS33 mount.
- Standard 1 1/8" headset.
- Try-All Oversized 31.8mm clamp aluminium handlebar (680mm) and stem (175mm x 35 deg) is much lighter and stronger than on other bikes at this price point.
- Try-All foam grips.
- Powerful Magura HS33 brakes front and rear, the same as can be seen on bikes 3 times this price!
- Drilled 39mm (front) and 47mm (rear) rims shod with Try-All Stiky tyres - an excellent wheelset at this price range!
- 118mm sealed bearing square taper bottom bracket with Try-All forged aluminium cranks in 158mm length.
- Dual caged VP pedals offer grip in all conditions.
- KMC Chain.
- 18T rear freewheel to give 24:18 gear ratio.
Geometry (to be confirmed)
Wheelbase: 990mm
Chainstays: 362mm
BB Rise: +45mm
Head angle: 71°
I would defonetly reccomend a T-pro! Ive never had one myself but have ridden lots, there brilliant, low cost begginer bikes!
- High quality 20" wheel trials bike from Onza, ideal for fast-learning beginners or intermediate riders.
- High grade U6 aluminium alloy frame.
- Tough Onza cromoly forks with 4-Bolt Magura brake mount and disc brake mount.
- Powerful Onza DD 'V' brakes front and rear, with Onza 4-Bolt to V brake adaptors included, which allows powerful Magura HS33 brakes to be bolted straight on in the future should the rider wish.
- Onza Skim rims, 20" front and 19" rear.
- Maxxis Creepy Crawler tyres (not the Onza Sticky Fingers shown), 20 x 2.0" front and 19 x 2.5" rear.
- New Onza T-Pro crankset with durable super-thick aluminium alloy bashring.
- Onza bash/ski-plate fitted as standard.
- Onza cromo stem and 'flat' trials handlebar.
- Onza caged/parallelogram pedals.
- Tensile 18T freewheel fitted to the cranks for great pedalling response and extra ground clearance, giving 18-12 gear ratio.
- Powder coat metallic brown/grey frame with matt black forks and Onza logos.
- Durable KMC K810 Kool chain fitted as standard.
£349 and worth every penny !
There sold out at the moment but due arround september
George x
