trials4life1 Posted August 25, 2008 Report Share Posted August 25, 2008 guys i have been wondering which bars and stem to use because i need wider bars and a stem further over the front endthanks Quote Link to comment Share on other sites More sharing options...
Aarron on a echo lite 08 Posted August 26, 2008 Report Share Posted August 26, 2008 Hello,i would get the zoo bars and an try-all over sized stem they work fine for me.Zoo bars, http://www.tartybikes.co.uk/product.php?pr...category_id=138try-all over sized, http://www.tartybikes.co.uk/product.php?pr...;category_id=29Thanks hope i helped,Aaron Danes. Quote Link to comment Share on other sites More sharing options...
Julius Czar Posted August 26, 2008 Report Share Posted August 26, 2008 HiI would recommend the echo team stem, or if you want a higher rise, get the viz and for bars, if you want a longer feel, get high rise bars and tilt them forward a bit, im currently using viz max bars and an echo team stem and it feels great.Hope this helps Kiwi Quote Link to comment Share on other sites More sharing options...
Jake Beach Posted August 26, 2008 Report Share Posted August 26, 2008 I would say an echo team stem and zoo bars. Quote Link to comment Share on other sites More sharing options...
Mikee Posted August 26, 2008 Report Share Posted August 26, 2008 zoo bars are fantastic in my opinion and then i would reccomend getting a long stem and tilting the bars forwards abit. Quote Link to comment Share on other sites More sharing options...
Aaron.Tottman Posted August 26, 2008 Report Share Posted August 26, 2008 Zoo bars are the daddy.never liked flat bars.if you don't know what stem to get check out http://www.tartybikes.co.uk/product.php?pr...;category_id=41gives you a ruff idea on what size to get. Quote Link to comment Share on other sites More sharing options...
javzi monty Posted August 26, 2008 Report Share Posted August 26, 2008 whats right for you really Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted August 26, 2008 Report Share Posted August 26, 2008 Mod or stock? Quote Link to comment Share on other sites More sharing options...
Muel Posted August 26, 2008 Report Share Posted August 26, 2008 I've got Monty TI bar and stem, they work perfectly for me. I use 20mm of stacks under the stem aswell.It all depends on you though, what do you prefer, how tall are you, what sort of riding you do etc. But it all just boils down to what you prefer. What bar and stem have you got now, it would help if we knew what you've got, so we can recommend a setup that is further foward and wider. Quote Link to comment Share on other sites More sharing options...
trials4life1 Posted August 26, 2008 Author Report Share Posted August 26, 2008 its a Mod Quote Link to comment Share on other sites More sharing options...
will pritchard Posted August 26, 2008 Report Share Posted August 26, 2008 I Recon you should go for Zoo Riser Bars for sure and if you like it forward go for the Onza t-master stem that is quite far forward and not to expensivehope i helped will x Quote Link to comment Share on other sites More sharing options...
Muel Posted August 26, 2008 Report Share Posted August 26, 2008 I Recon you should go for Zoo Riser Bars for sure and if you like it forward go for the Onza t-master stem that is quite far forward and not to expensivehope i helped will xThe T-Masters are really short and really high, my brother had one. The steep angle means that it was shorter than the Monty PR he has now. Quote Link to comment Share on other sites More sharing options...
will pritchard Posted August 26, 2008 Report Share Posted August 26, 2008 The T-Masters are really short and really high, my brother had one. The steep angle means that it was shorter than the Monty PR he has now.O Poo sorry i ment the Try-all Oversized sorry they are the longest i've seen on my mates bike sorry about the mix up please forgive will x Quote Link to comment Share on other sites More sharing options...
Muel Posted August 26, 2008 Report Share Posted August 26, 2008 Ah yeh they're pretty long, I think an Echo Team is slightly longer though, but the Try-All was the longest I've ever tried. Quote Link to comment Share on other sites More sharing options...
