Aarron on a echo lite 08 Posted August 24, 2008 Report Share Posted August 24, 2008 hello,I getting a disc on the front and i need help what one should i get and i would need to get a new hub aswell i have got £200 to get what i need.thanks Aaron Quote Link to comment Share on other sites More sharing options...
bigamac Posted August 24, 2008 Report Share Posted August 24, 2008 have a look on tarty bikesthey have a few things up on there and what brakes you have atm? Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted August 24, 2008 Report Share Posted August 24, 2008 Avid BB7s are highly recommended by many on here,And they're a lot cheaper than any decent hydraulic disk too. Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted August 24, 2008 Report Share Posted August 24, 2008 Avid BB7s are highly recommended by many on here,And they're a lot cheaper than any decent hydraulic disk too.my mates was wa*k and now he got a hope its the best thing he ever did Quote Link to comment Share on other sites More sharing options...
Muel Posted August 24, 2008 Report Share Posted August 24, 2008 Front Hope Mono Trial, any disc hub with sealed bearings. Monty TIs are good because the rotor bolts can run right through the spoke flange, so you can run super long bolts, so no risk of stripping the threads out of the rotor mounts! (Unless you like over tightening things!) Quote Link to comment Share on other sites More sharing options...
Sam-Addy A3 Posted August 24, 2008 Report Share Posted August 24, 2008 Hey, with £200 you can get alot!As for a front brake, avid bb7s are amazing, great hold and have a really nice lever feel if set up properly.The brake by its self with set you back £40 but you will need to buy a lever and cable.Brake: http://tartybikes.co.uk/product.php?produc...;category_id=12 £40Lever: http://tartybikes.co.uk/product.php?produc...;category_id=71 £11and you can get a cable from tescos or somewhereYou will then have £145 pounds left for a hub.This means you can afford one of the best hubs on the market and have some cash left overChris king hub: http://tartybikes.co.uk/product.php?produc...;category_id=20There are many other hubs on the market if you don't want to spend too much but with a chris king hub and an avid bb7 you will have a truly amazing setup.Hope this helpedSam Quote Link to comment Share on other sites More sharing options...
Alien Posted August 24, 2008 Report Share Posted August 24, 2008 I'd say you have no reason to spend a load of money on a front, theoretically, all it has to do is hold bearings, so something like a Hope Pro II (which I personally use, its been flawless), or a Pro II XC if your worried about weight.For the brake I've heard good things about the Hope Mono Trials, allthough can't comment on it personally.Any reason you specifically want a front disc? Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted August 24, 2008 Report Share Posted August 24, 2008 Hope mono trials and pretty much any disc front hub. Front hubs aren't really that important as they usually don't break. Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted August 25, 2008 Report Share Posted August 25, 2008 bt front hub-£30 on sale at tarty,cheap,strong,decent bearings and looks pretty good.avid bb7 203mm-£50,avid sd7 levers-£15,tesco cable-£2great setup,mines really powerful and holds and bites like a beast.total price £97 ,bargain and you can spend the change on other parts and beer Quote Link to comment Share on other sites More sharing options...
Elliot Posted August 25, 2008 Report Share Posted August 25, 2008 bt front hub-£30 on sale at tarty,cheap,strong,decent bearings and looks pretty good.avid bb7 203mm-£50,avid sd7 levers-£15,tesco cable-£2great setup,mines really powerful and holds and bites like a beast.total price £97 ,bargain and you can spend the change on other parts and beerI do exactly that, except I'd probably spend a bit more on the cable and get an oddessy linear slick or similar, rather than a cheap one that may stretch and not run quite so smooth. Personal prefernce though. Quote Link to comment Share on other sites More sharing options...
Jake Beach Posted August 25, 2008 Report Share Posted August 25, 2008 Get a hope mono trials with a 160 or 180mm rotor and a trialtech hub from tartybikes Quote Link to comment Share on other sites More sharing options...
16 years later Posted August 26, 2008 Report Share Posted August 26, 2008 Hey, with £200 you can get alot!As for a front brake, avid bb7s are amazing, great hold and have a really nice lever feel if set up properly.The brake by its self with set you back £40 but you will need to buy a lever and cable.Brake: http://tartybikes.co.uk/product.php?produc...;category_id=12 £40Lever: http://tartybikes.co.uk/product.php?produc...;category_id=71 £11and you can get a cable from tescos or somewhereYou will then have £145 pounds left for a hub.This means you can afford one of the best hubs on the market and have some cash left overChris king hub: http://tartybikes.co.uk/product.php?produc...;category_id=20There are many other hubs on the market if you don't want to spend too much but with a chris king hub and an avid bb7 you will have a truly amazing setup.Hope this helpedSam what are you talking about you can get a king on ebay for £80 with 5 year warranty Quote Link to comment Share on other sites More sharing options...
Aaron.Tottman Posted August 26, 2008 Report Share Posted August 26, 2008 (edited) hello,I getting a disc on the front and i need help what one should i get and i would need to get a new hub aswell i have got £200 to get what i need.thanks Aaronavid bb7 no smaller than 180mm (i run 203 replacing my hope mono 160mm) with any v-brake lever. £50-£60the hope brakes are great but not worth the money over a bb7only prob i've ever had with a bb7 is it locked up on me on one ride. my fault i didn't grease the arm bearings and it seased up.took it appart, greased it up and it's still working better than ever.and hope front hub all the way. bout £40all you want with half the budget!?!?!?!???!?!!! Edited August 26, 2008 by Aaron.gloster Quote Link to comment Share on other sites More sharing options...
will pritchard Posted August 27, 2008 Report Share Posted August 27, 2008 my mates was wa*k and now he got a hope its the best thing he ever didyeah but if you get the Avid BB set up well it is just as good or maybe better than the hopes,and for a hub get the hope pro II it is lush Quote Link to comment Share on other sites More sharing options...
smithy Posted August 27, 2008 Report Share Posted August 27, 2008 my mates was wa*k and now he got a hope its the best thing he ever didYeah! Don't bother with an Avid, just go for the Hope. There pretty sick.And for a hub. Its totally up to you, depends on what kind of rider you are. If you're a smooth rider you can run pretty much anything, because you wont brake it. I run a T-master hub up front (nothing special) but it does the job. But if you're a crazy street basher you might fancy somethig more stronger like a king or something deng like.Smithy x Quote Link to comment Share on other sites More sharing options...
