AdamR28 Posted August 23, 2008 Report Share Posted August 23, 2008 Pictures on th Echo website: http://www.echobike.com/I will update with specs and weights when the topic has been approved ThanksAdam Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 23, 2008 Report Share Posted August 23, 2008 I wonder if the sales of drills and related items will drop significantly in the UK now Echo have released the 'pre-drilled' SL range? Quote Link to comment Share on other sites More sharing options...
manuel Posted August 23, 2008 Report Share Posted August 23, 2008 I wonder if the sales of drills and related items will drop significantly in the UK now Echo have released the 'pre-drilled' SL range?maybe go up - as people realise they should have been drilling their cranks all this time ... Quote Link to comment Share on other sites More sharing options...
Ashley-Wood Posted August 23, 2008 Report Share Posted August 23, 2008 SExy Quote Link to comment Share on other sites More sharing options...
Josh Greenan!!!!!!!!!! Posted August 23, 2008 Report Share Posted August 23, 2008 Those rims look very nice. Quote Link to comment Share on other sites More sharing options...
Greetings Posted August 23, 2008 Report Share Posted August 23, 2008 Good stuff that. Calculated that a complete Echo Control 2009 should weigh around 9,1kgs with Schwalbe tyres and a thick rear inner tube. Combine that with some Trialtech parts and you've got yourself an even lighter bike. Quote Link to comment Share on other sites More sharing options...
Z o o !! Posted August 23, 2008 Report Share Posted August 23, 2008 Everything is so mint. Rims loook SOoooo nice, 32 hole only Quote Link to comment Share on other sites More sharing options...
Adrian Posted August 24, 2008 Report Share Posted August 24, 2008 what about the new new dengura's! those levers look niiicee!!! and simple, with a decent tpa!!!! (the tr range)and the pimp bar ends hahah Quote Link to comment Share on other sites More sharing options...
Andrew Smith Posted August 24, 2008 Report Share Posted August 24, 2008 hmm are we sill going to be able to buy he 07 echo rims still of are these a replacement Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 24, 2008 Author Report Share Posted August 24, 2008 It appears so, they will be in the 'Urban' range. Quote Link to comment Share on other sites More sharing options...
The Duck Posted August 24, 2008 Report Share Posted August 24, 2008 Impressed with this new stuff!One thing thats puzzling me though - 12mm axle diameter? Its mentioned quite a lot on the echo website (talking about the hubs and tensioner)Does this mean all the hubs will have 12mm axels rather than the standard 10mm? So the forks will be cut to fit etc etc meaning that you couldn't use other components with echo ones? I.e. Hope hub with Echo forks Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 24, 2008 Author Report Share Posted August 24, 2008 They are 12mm diameter where the bearing is, but then turned down to 10mm for the dropout... means you get a stronger axle at the areas necessary. The current rear hubs are the same Quote Link to comment Share on other sites More sharing options...
The Duck Posted August 24, 2008 Report Share Posted August 24, 2008 Ahhh right. That makes sense. Quote Link to comment Share on other sites More sharing options...
Monty99 Posted August 24, 2008 Report Share Posted August 24, 2008 there are now some previews of the frames on www.echobike.comlooking interesting. especially the idea of tensioning Quote Link to comment Share on other sites More sharing options...
txt2007 Posted August 24, 2008 Report Share Posted August 24, 2008 if this is the way trials is going them we need an emote that drops his pants because with beatifull art like this on our bikes alot of bodily fluids are going to be lost. Quote Link to comment Share on other sites More sharing options...
Alex-Mitchinson Posted August 24, 2008 Report Share Posted August 24, 2008 Prices are steep, but defintely worth it on a lot of those parts! Quote Link to comment Share on other sites More sharing options...
The Duck Posted August 24, 2008 Report Share Posted August 24, 2008 Horizontal dropouts. Thank God for that!Not too sure on the tensioning system... If brake mount threads on previous threads are anything to go by. Can always helicoil it though I suppose. Looks mint otherwise, as long as its not flexy.Want to see the zoo frames!! Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 24, 2008 Author Report Share Posted August 24, 2008 It's an M6 thread, as opposed to M5 on brake mounts. If anyone strips that thread I will personally go round to their house and sellotape ham onto their fists Quote Link to comment Share on other sites More sharing options...
N Roach Posted August 24, 2008 Report Share Posted August 24, 2008 (edited) The new Echo Control 09!, can we run a Pro II hub with the tensioning bolts in the frame? Wont the axle threads be crushed by the tensioning bolt? Or do we need to have an echo hub? Like with the Atomz new frame. Edited August 24, 2008 by Nathan Coward Quote Link to comment Share on other sites More sharing options...
The Duck Posted August 24, 2008 Report Share Posted August 24, 2008 It's an M6 thread, as opposed to M5 on brake mounts. If anyone strips that thread I will personally go round to their house and sellotape ham onto their fists So, is that a prize or punishment? Imagine that on a ride... 'Yeah, tarty came round the other day' 'Oh did he? What one earth for?' 'Wanted to sellotape ham to my fists' 'Oh right.' Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 24, 2008 Author Report Share Posted August 24, 2008 The new Echo Control 09!, can we run a Pro II hub with the tensioning bolts in the frame? Wont the axle threads be crushed by the tensioning bolt?Yeah, you can run it like that. I very much doubt the tensioning bolts would damage the thread on the axle bolt, but even if they did a little, it's outside the hub so this wouldn't affect the internal thread on the hub's axle.So, is that a prize or punishment? Punishment Quote Link to comment Share on other sites More sharing options...
Muel Posted August 24, 2008 Report Share Posted August 24, 2008 On a Pro2, the bolts have a plain shank anyway for the part that sits inside the frame, so I shouldn't think there is much chance of it being damaged. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 24, 2008 Author Report Share Posted August 24, 2008 Your posh titanium ones do, the standard ones don't http://www.tartybikes.co.uk/product.php?pr...;category_id=75 Quote Link to comment Share on other sites More sharing options...
Muel Posted August 24, 2008 Report Share Posted August 24, 2008 Ooh, I feel quite special now. Are any more of the bolts titanium? Quote Link to comment Share on other sites More sharing options...
joey vajda Posted August 24, 2008 Report Share Posted August 24, 2008 Ooh, I feel quite special now. Are any more of the bolts titanium?I think almost all the bolts they use are titanium now, other than the V booster on the urban series. I think the TR stem as well, which looks like the forged echo stems. Quote Link to comment Share on other sites More sharing options...
