dave33 Posted August 19, 2008 Report Share Posted August 19, 2008 here ok does any one use this and oes it actually give more power? i used to have an rb lever and i really liked it if only it didnt slowly leak then i would still have it secoundly are these reliable ? sorry if its been asked before Quote Link to comment Share on other sites More sharing options...
cai Posted August 19, 2008 Report Share Posted August 19, 2008 Apparently these leek like a bitch....Wack a CNC lever blade on your maggie oh no, you've got an 04... hmm.I had a C'zar lever on my maggie (before switching to vee's) and felt wank! You had to pull it far too close to the bar for it to hit the rim (with pads really close to the rim) - so wasn't ideal for me Worth a go though? But your maggie didn't seem bad last time we rode. Quote Link to comment Share on other sites More sharing options...
HarshRider Posted August 20, 2008 Report Share Posted August 20, 2008 i wouldnt really think it would be worth it in my opinion, i have never had a problem with using ether the 04 or the new current levers.they both provide excellent locking potential, anything else is over kill. imothey only other levers i liked in the past is the rb levers, so comfy. Quote Link to comment Share on other sites More sharing options...
forteh Posted August 20, 2008 Report Share Posted August 20, 2008 Use an RB lever, if the seals start to leak put new ones in Mines still fine after 3 years. Quote Link to comment Share on other sites More sharing options...
dave33 Posted August 20, 2008 Author Report Share Posted August 20, 2008 Use an RB lever, if the seals start to leak put new ones in Mines still fine after 3 years.well when the material is worne away new seals dont help, mine was good for few years Quote Link to comment Share on other sites More sharing options...
JonMack Posted August 20, 2008 Report Share Posted August 20, 2008 Machine the inside out and put a maggie master cylinder in there? Quote Link to comment Share on other sites More sharing options...
dave33 Posted August 20, 2008 Author Report Share Posted August 20, 2008 Machine the inside out and put a maggie master cylinder in there?and have a Ø14 rather than Ø13 piston, wouldnt that defeat the object ? Quote Link to comment Share on other sites More sharing options...
tris Posted August 20, 2008 Report Share Posted August 20, 2008 £80!!! What a rip off! I quite like my stanard one. If i broke it i would go for an anodised one, just for the look, but i would never spend more than £20. Quote Link to comment Share on other sites More sharing options...
Bigman Posted August 20, 2008 Report Share Posted August 20, 2008 The echo levers have exactly the same piston size as the magura's (may have already been said) but the lever blades are slightly longer so theoreticaly you do get a little more power because of that.And as has already been said they have been known to leak......AdamPS: I have an 08 lever blade for sale if u wanted to try one.... Quote Link to comment Share on other sites More sharing options...
Ashley-Wood Posted August 20, 2008 Report Share Posted August 20, 2008 best brake i have ever had! i have had mine for a few weeks now no sign of leeking what so ever! and it was second hand!feels so nice and looks the tits! Quote Link to comment Share on other sites More sharing options...
Grant Peters Posted August 21, 2008 Report Share Posted August 21, 2008 £80!!! What a rip off! I quite like my stanard one. If i broke it i would go for an anodised one, just for the look, but i would never spend more than £20.This one is'nt £80 although it also is'nt £20 either Quote Link to comment Share on other sites More sharing options...
dave33 Posted August 21, 2008 Author Report Share Posted August 21, 2008 The echo levers have exactly the same piston size as the magura's (may have already been said) but the lever blades are slightly longer so theoreticaly you do get a little more power because of that.And as has already been said they have been known to leak......AdamPS: I have an 08 lever blade for sale if u wanted to try one....whats the difference ? Quote Link to comment Share on other sites More sharing options...
Ali C Posted August 21, 2008 Report Share Posted August 21, 2008 not heard of any leaking problems for a while now! I think there was a tiny amount of swarf in the origional Echo bodies (tiny amount!) that just upset the seals a tad. I beleive they are now cleaned more before assembly and it seems to have solved the issues. Quote Link to comment Share on other sites More sharing options...
ti-mig-guy Posted August 21, 2008 Report Share Posted August 21, 2008 Does anyone have experience with the GU levers? They look like they would be nicer for the fingers, more ergonomically correct looking. Quote Link to comment Share on other sites More sharing options...
Simpson Posted August 22, 2008 Report Share Posted August 22, 2008 just get an 04 maggie lever body out of a friends garage, and whip your RB lever in with a bit of filing... happy days Quote Link to comment Share on other sites More sharing options...
georgieporgie Posted August 23, 2008 Report Share Posted August 23, 2008 Try this?Echo TR BrakeLooks interesting and not too expensive. Its a complete rip of an rb but probably wont leak . Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted August 23, 2008 Report Share Posted August 23, 2008 Just stick with the Maggie lever. You've got the 04' so it's the best one ever. No need in spending extra money for no reason. Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted August 23, 2008 Report Share Posted August 23, 2008 I swapped my Eisbar magura for a Dengura, worst mistake i ever made, i found the blade uncomfortable, the TPA ate my finger and the lever and it was constantly leaking I wouldn't suggest it, especially when you've got an 04, there great Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted August 23, 2008 Report Share Posted August 23, 2008 Try this?Echo TR BrakeLooks interesting and not too expensive. Its a complete rip of an rb but probably wont leak .that looks FIT Quote Link to comment Share on other sites More sharing options...
michael danes Posted August 24, 2008 Report Share Posted August 24, 2008 here ok does any one use this and oes it actually give more power? i used to have an rb lever and i really liked it if only it didnt slowly leak then i would still have it secoundly are these reliable ? sorry if its been asked beforehello mate,my mate has an echo magura lever and it give more power than a normal magura lever thanks mike Quote Link to comment Share on other sites More sharing options...
