Photoshopists
Davetrials
46 seconds in to this video, her teeth are like painted rred then the colours messed with, i keep seeing this tool, what is it?
if i was gonna go about that id have to use the pen tool...
Youtube Video ->
" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
quick mask
Use 'Q' to activate it.
Its one of the lowest buttons on the control list.
It resembles a rectangle with a circle in it. The one on the right is to activate it, the one on the left, deactivate. Note, the brush/eraser will only work when in standard mode, not, for example, in multiply/colour burn/dodge/etc.
Whatever you paint red will be masked off, so it selects everything but. Then you can invert the selection, and just select the red bit.
This is good cause you can mask with any opacity which equals feather level when deactivated. It also lets you mask any shape you can set the brush to.
Changing the colour is probably the colour balance tool.
Poor job though imo, the video.
HAHAHA
Edited by Revolver
haha how big did her head look compared to her body at the end?
The red bit is a way of showing where you've painted if you like, on mac it's activated by pressing "\" or "/" I can't remember.
Then the colour was changed with the Hue/sat?
