G_! Posted August 19, 2008 Report Share Posted August 19, 2008 (edited) hi!last month i tested a v-brake front in trials bike 20", is AWSOME!!!! like brake disc or better!!!my question is... How would be this brake for rear? better that hidraulic? i need adapters? is stupid idea?thanks Edited August 19, 2008 by GUILPU Quote Link to comment Share on other sites More sharing options...
onzatrip Posted August 19, 2008 Report Share Posted August 19, 2008 DO IT i got rear vee on mine and its a beast DO IT i tell you do it now Quote Link to comment Share on other sites More sharing options...
Alex@Flawless Bikes Posted August 19, 2008 Report Share Posted August 19, 2008 As long as you get a good rear vee like an avid ultimate, but then again that will probally cost you more then a maggie or disc. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted August 19, 2008 Report Share Posted August 19, 2008 nah i got sd7 arms tesco cable and avid lever works the treat alright with tar Quote Link to comment Share on other sites More sharing options...
George ZHI Posted August 19, 2008 Report Share Posted August 19, 2008 As long as you ride great pads (plaz etc.) then i guess it should bite well and hold well on gaps etc. I would do it mate! george x Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted August 19, 2008 Report Share Posted August 19, 2008 To continue the trend:AS LONG AS you set it up properly, you'll be fine - a lower end but affordable brake (SD7 arms/lever or similar) will do just fine with some half decent pads and a good cable, though Ultimates can be found cheaply if you look in the right places Quote Link to comment Share on other sites More sharing options...
biker_boy Posted August 20, 2008 Report Share Posted August 20, 2008 yes but that v brake is not that strong (mean the magura is good because is make from oil and that make it to don`t crash or different stuff) v brake is not make for that strong ride like trial bikes. They need more but yeah I was ride and is really nice is not that much money and don`t have problem with oils pads and more different stuff but the bikes are make for 4 bolt for make you self safe from punch or like that stuff for more help to the frame went you ride that what I think but and v brake are really nice man !!!! Quote Link to comment Share on other sites More sharing options...
jack14366 Posted August 20, 2008 Report Share Posted August 20, 2008 (edited) I used to have v breaks on my t-pro there horrible get maggy's they have 10 times the holding power even if the v's have plaz pads ( and if u go with maggy's I recomend koxx bloxx they hold well ) hope I helped ! Edited August 20, 2008 by jack14366 Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted August 20, 2008 Report Share Posted August 20, 2008 yes but that v brake is not that strong (mean the magura is good because is make from oil and that make it to don`t crash or different stuff) v brake is not make for that strong ride like trial bikes. They need more but yeah I was ride and is really nice is not that much money and don`t have problem with oils pads and more different stuff but the bikes are make for 4 bolt for make you self safe from punch or like that stuff for more help to the frame went you ride that what I think but and v brake are really nice man !!!!I was going to refrain from getting rowdy due t expecting you to be foreign with such an appalling grasp of the English language, but if it turns out you're just retarded...Care to re-write that in a way that people can actually understand?I used to have v breaks on my t-pro there horrible get maggy's they have 10 times the holding power even if the v's have plaz pads ( and if u go with maggy's I recomend koxx bloxx they hold well ) hope I helped !You used to have the standard cheap and relatively nasty vee on the t-pro I assume? I also assume you didn't take the time to set it up properly, or to maintain it correctly?You also don't realise how unbelievably wrong you are about maggies having more hold than a vee - like for like the Magura may offer more bite, but hold is another matter altogether Quote Link to comment Share on other sites More sharing options...
javzi monty Posted August 20, 2008 Report Share Posted August 20, 2008 get a cheapish vee get pads and a lever works mint Quote Link to comment Share on other sites More sharing options...
Al_Fel Posted August 20, 2008 Report Share Posted August 20, 2008 I've had SD7s and Ultimates if I were to run a V again I'd choose SD7's. They are cheap, strong and hold great. The standard pads that come with SD7's are great on a smooth rim as long as the rim is clean. I'd suggest Plaz or Rock pads on a grind though. Quote Link to comment Share on other sites More sharing options...
G_! Posted August 21, 2008 Author Report Share Posted August 21, 2008 oks people, thanks fr all comments for the moment I will continue with hydraulic, but maybe i buy V-brake in nearby future.thanks Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 21, 2008 Report Share Posted August 21, 2008 I've had SD7s and Ultimates if I were to run a V again I'd choose SD7's. They are cheap, strong and hold great. The standard pads that come with SD7's are great on a smooth rim as long as the rim is clean. I'd suggest Plaz or Rock pads on a grind though.Are they the Avid Rim Wrangler pads? Think I ran some BITD. I never really had a problem with V's when I ran them, but then I got a pair of Maguras on a different bike and didn't really have any problems with them either. If you've got a bit of mechanical know-how you should be fine with either, really. There are plenty of ways to set up a brake so it feels good and works well, so just do whatever, really. Quote Link to comment Share on other sites More sharing options...
