Onza 8 Speed Fixed Rear Disc Hub
J Trials 31
Fixed doesn't really matter. Got a 22 tooth chainring and a WI laying around. Any more suggestions on what I should get then. Hope Pro 2 sounds like a good bet, but will it handle trials? Didn't know there were two different Pro 2's. Also, does it have the same engagement as the trials version?
Edited by J Trials 31
I'm not certain, but I'm pretty sure the Trials one has more engagement points.
Just get the trials one and run 6 speed, the Pro2 Trials is worth the extra money over a mono or and XC, and probably a normal Pro2 aswell if you ask me.
Yeah, I think your right. Hope Pro 2 trials it is. I can actually get the trials version cheaper than the regular one anyway. What's a good cassete to use? Might be able to use the current one, but not sure as it's 9 speed so will have to take all of it apart.
  Revolver said:
this is the one I meant.
I've only seen pictures of it briefly, and talked about it with my friend a similar amount.
You'd need a different cassette and shifter, your derallieur might do the job anyway.
Sorry, lol.
Yeah sorry, I misunderstood. I need a rear disc mount so that won't work. So looks like Hope it is.
