Brake Booster
sstein
I use a tensile 4 bolt booster and I am getting annoyed that I can't fit my pads in without cutting them down. Would you say that a two bolt booster is good enough? I know that power will be Ok but will my frame break because all the stress will be on the lower bolts?
How will changing to a 2 bolt booster stop you needing to cut your pads down? Unless you're using Evo mounts and find a booster with a wider spacing than the default one you'll still need to cut the pads down to make them fit. Do the pads foul on the brake booster or something?
  • 8 months later...
Bit of an old topic, but can´t be bothered to make a new one.
What exactly are the differences in 2 bolt- and 4 bolt boosters, other than the way they are installed?
Do 4 bolt booster reduce the flex more or something?
Also, is there any way a booster could harm your frame by being "too" stiff?
Might be stupid questions, but I was curious.
Basically a 4-Bolt booster will be stiffer than a 2-Bot one. Im personally not a huge fan of boosters. They kill alot of the bite and i dont like the feel of it that much.
However though. I am running a tiny wee skinny 2-Bolt booster on both my brakes and there is very little flex atall.
A 4-Bolt booster will not harm your frame by being too stiff. If anything it should make it last even longer(Unless you are a fat basher, Then your frames pretty much doomed anyway).
Oke thanks alot, cleared it up for me :)
