Creating The Perfect Brake Pad.
Hannah Shucksmith
After being told by Dave (mrkoxx) that I was smart enough to come up with the perfect solution, Beth and I have been researching and developing a chemical formula to actually create what would be the perfect brake pad. We've now just got to figure out which catalyst you would need to add to the formula in order to not blow yer face off...
Wreyy! (Y)
p.s.
the formula is currently about 5 pages long. we're nerds (:
-Hannah and Beth!
x
hannah and beth ey :P
koxx browns = perfect
it is possible!
we tell yeeeee it's possible!
the material used for it is the polyurathane polymer correct? and the equation up there, is just the formula for part of that, we just broke it down and found out the exact elements, compounds and ions its made of, and then when you balance it out it pretty much gives the perfect formula of the polyurathane polymer.
And that's only a bit of it... (:
Look at my signature ;)
Its not as simple as that. End of.
i think we need more people like you on this forum!!!!.
next job - work out the perfect length bike............................... you cant really invent a perfect because if you asked 100 people on what there perfect pad would be.....
some would say something that holds amazing but doesnt bite and can be used on smooth rim
some would say heaps of bite and hold on a medium ground rim..
the list would go on.
so yeeeeeeeeeer........... keep going and maybe you will find the formula for a sick pad. but it'll only be perfect for some people :)
Edited by rudirudirudirudirudi
Under the same principles you listed... that also isn't possible.
we know it isnt thattttt simpleeee, cause we've only figured out like one part of it
leave us aloneeee :(
meanies.
Its not a case of simplicity, it just isn't possible to create one perfect pad. There are too many outside variables that have to be taken into consideration, plus peoples differing opinions on the perfect pads features.
