CZARKID Posted August 13, 2008 Report Share Posted August 13, 2008 hey, when i apply the brake the pads push away from the wheel and leave me with a lever that i can touch the bar with. I'm using a hs33 with standard hose and clamps, adamant 4 bolt booster and zoo pads. any help would be appreciated. thanks in advance tomo. Quote Link to comment Share on other sites More sharing options...
ogre Posted August 13, 2008 Report Share Posted August 13, 2008 your clamps might not be tight enough? sounds like the slaves are sliding through the clamps? tighten the bolts more, otherwise, try bleeding your brake could be air in the hosing being squashed Quote Link to comment Share on other sites More sharing options...
onzatrip Posted August 13, 2008 Report Share Posted August 13, 2008 that happens because you need a brake booster as your frame you have might be realy flexyhope i could helptris Quote Link to comment Share on other sites More sharing options...
Ryan-Trials Posted August 13, 2008 Report Share Posted August 13, 2008 that happens because you need a brake booster as your frame you have might be realy flexyhope i could helptrislol Cant you read?he said he had an adamant brake boosterand bleed it with water and tighten the all the bolts or try a new booster?Ryan Quote Link to comment Share on other sites More sharing options...
Andrex Posted August 13, 2008 Report Share Posted August 13, 2008 You may need new cylinder washers. Quote Link to comment Share on other sites More sharing options...
JDâ„¢ Posted August 13, 2008 Report Share Posted August 13, 2008 It's the follywoggle. Fo' sho. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted August 13, 2008 Report Share Posted August 13, 2008 lol Cant you read?he said he had an adamant brake boosterand bleed it with water and tighten the all the bolts or try a new booster?Ryanhe has edited his post when i looked didnt have that Quote Link to comment Share on other sites More sharing options...
G-baby158 Posted August 13, 2008 Report Share Posted August 13, 2008 he has edited his post when i looked didnt have thatNo he hasn't, yeah just try doing your bolts up or you might need to bleed it. Quote Link to comment Share on other sites More sharing options...
Ryan-Trials Posted August 13, 2008 Report Share Posted August 13, 2008 he has edited his post when i looked didnt have thatwhere can you see that it said he edited it?and just read things thoroughly before replying Ryan Quote Link to comment Share on other sites More sharing options...
onzatrip Posted August 13, 2008 Report Share Posted August 13, 2008 i read it when i opened i might be wrong if so im sorry Quote Link to comment Share on other sites More sharing options...
control rob Posted August 13, 2008 Report Share Posted August 13, 2008 hellolike the other i would say tighten up your clamps, rebleed, or buy a new booster? i bought the echo control booster and i didnt have any movement with my brake so i would recommend that, but it is quite big n heavy for a booster...rob Quote Link to comment Share on other sites More sharing options...
CZARKID Posted August 13, 2008 Author Report Share Posted August 13, 2008 i can't get my clamps any tighter. so i'm going to put the cylinder washers of an old bike on to see if its any better with them on.tomo Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted August 13, 2008 Report Share Posted August 13, 2008 i can't get my clamps any tighter. so i'm going to put the cylinder washers of an old bike on to see if its any better with them on.tomoi bet your bolts are bottoming out on the frame, try some slightly shorter bolts if you can Quote Link to comment Share on other sites More sharing options...
CZARKID Posted August 13, 2008 Author Report Share Posted August 13, 2008 also what is the best distance to set the pads away from the rim or is it just what feels besttomo Quote Link to comment Share on other sites More sharing options...
Ladd Posted August 13, 2008 Report Share Posted August 13, 2008 i bet your bolts are bottoming out on the frame, try some slightly shorter bolts if you canYeah was just about to say that! happend with my mates Zoo! booster.. Quote Link to comment Share on other sites More sharing options...
Z o o !! Posted August 13, 2008 Report Share Posted August 13, 2008 Check for cracks on your frame, change you magura cylinder washers. Shorten your bolts. Give it a fresh bleed. job job. Quote Link to comment Share on other sites More sharing options...
Ali C Posted August 13, 2008 Report Share Posted August 13, 2008 another vote for the bolts being too short Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted August 13, 2008 Report Share Posted August 13, 2008 another vote for the bolts being too short long Quote Link to comment Share on other sites More sharing options...
Ali C Posted August 13, 2008 Report Share Posted August 13, 2008 I meant something along those lines Quote Link to comment Share on other sites More sharing options...
StevenJJ Posted August 13, 2008 Report Share Posted August 13, 2008 Might sound stupid but have you got the spacers on the bolts under the booster? That would explain the bolts bottoming out. Quote Link to comment Share on other sites More sharing options...
StevenJJ Posted August 13, 2008 Report Share Posted August 13, 2008 (edited) Double post Edited August 13, 2008 by sjjKOXX Quote Link to comment Share on other sites More sharing options...
CZARKID Posted August 13, 2008 Author Report Share Posted August 13, 2008 yeh mate got the spacers on right i'll try sum shorter bolts would it be ok to cut them or should i just buy sum new ones??tomo Quote Link to comment Share on other sites More sharing options...
txt2007 Posted August 14, 2008 Report Share Posted August 14, 2008 just grind them (is that the word?) like on the machine with a stone disk press against the bolt for a second or two dip it in water to cool it down but first i'd draw a line of how much you need to remove Quote Link to comment Share on other sites More sharing options...
Krisboats Posted August 14, 2008 Report Share Posted August 14, 2008 Be very careful when cutting them though, the bolts will more than likely end up with damaged thread which can easily strip the threads in your frame. Quote Link to comment Share on other sites More sharing options...
