anzo Posted August 13, 2008 Report Share Posted August 13, 2008 Help!Trying to strech an image (import from Visio) into word. Need it to go across two pages but it gets cut up at the margins.Help? I think its something really basic, but my brains on shutdown! Quote Link to comment Share on other sites More sharing options...
munkee Posted August 13, 2008 Report Share Posted August 13, 2008 (edited) across as in landscaped? just rotate the image or switch the page to landscaped...oracross as in.. it breaks off at bottom margin and continues on to next page? if so since its an imported image it wont but to stop the cutting off at bottom, move the margin at the bottom down which you can adjust with the bar on the left (where the colour changes from white to blue on the bar is where it cuts) it may give you enough room to see the full image. Edited August 13, 2008 by munkee Quote Link to comment Share on other sites More sharing options...
froggy Posted August 13, 2008 Report Share Posted August 13, 2008 In the bottom right corner where the numbered measure is. You see where it goes from white to blue? hover your mouse around the margin where the colors swap and it should allow you to reduce/increase the size of the margin.I think thats what you mean, hope it helps. Quote Link to comment Share on other sites More sharing options...
King C Posted August 13, 2008 Report Share Posted August 13, 2008 If its loads longer then crop it at the bottom, then re-insert the image but crop it to show the other halfon the next page. Then decide what to do with the arrow. Atleast I think thats what you want to do. Quote Link to comment Share on other sites More sharing options...
anzo Posted August 13, 2008 Author Report Share Posted August 13, 2008 If its loads longer then crop it at the bottom, then re-insert the image but crop it to show the other halfon the next page. Then decide what to do with the arrow. Atleast I think thats what you want to do.Yup, thats what I ended up doing in the end....bloody pain in the arse, its about 4 pages long!Thanks Y'all! Quote Link to comment Share on other sites More sharing options...
