Aol
Z o o !!
Hello,
When ever i go to sign on into aol, its checks my connection and password and all that then logs me straight off and sais " You are unable to sign in using this method" Wth ?
Ive tried using aol auto fix but it sais we were unable to solve this problem. ( Great help).
Can anyone help me ?
This seems like a heavy electricity problem, quite common with AOL for some reason.
It happens if you live over a deposit of ferrite or under power lines.
The most effective fix is pretty simple, pick up the computer in question, turn it 90 degrees CCW and then let go.
Also, getting a better ISP could work too.
Another way around most HEPs is to create a faraday cage around the computer for some reason. Even though this is a completely different branch of science related to electromagnetic waves, people who have clad their house or even bedroom walls with sheet metal to a thinkness of around 1.5cm have effectively solved the problem.
But it definately sounds like you live in a HEP affected area.
