Ben-jamin' Posted August 10, 2008 Report Share Posted August 10, 2008 The most common advice I get from people to improve my riding is to "gap from the edge." I have a hard time doing this.. I find once I'm on the edge of what I'm gapping from I just roll right off and get no distance at all compared to "rolling into the gap." Can someone break down what exactly I need to do? I tried the Wiki but it did nothing for me.. This is the most recent footage of me (i'm on the red Meta): Please help me correct my poor technique!Ben Quote Link to comment Share on other sites More sharing options...
spartan Posted August 10, 2008 Report Share Posted August 10, 2008 yeah i have a really similar problem, ive tried going right to the edge with just a tiny pedal kick but dont get any distance.Any help is much appreciated!! Quote Link to comment Share on other sites More sharing options...
cwbashaw Posted August 10, 2008 Report Share Posted August 10, 2008 I posted something similar a few days ago on OTN I was told 2 things...1. "Jump up! There's a fundamental change that has to happen in your technique. Generally when you start pedal kicking you rely heavily on the pedal kick itself. Unfortunately, as you have found out, on very narrow obstacles that just won't work. Try to use your body more. Preload your body/tire and think about jumping up almost more than jumping forward and just give a short stab at the pedals."2. "Your biggest problem is probably letting the brake off too early. Try to consciously delay letting the brake off until after your comfort point."I'm still working at it so I'm no pro, but letting the brake off a little later, and kicking just as hard, but with a shorter stroke has helped the most.I've been practicing this on a small concrete parking bumpers, and working on increasing the distance. Im getting better but not consistent yet. Quote Link to comment Share on other sites More sharing options...
Ben-jamin' Posted August 10, 2008 Author Report Share Posted August 10, 2008 I posted something similar a few days ago on OTN I was told 2 things...1. "Jump up! There's a fundamental change that has to happen in your technique. Generally when you start pedal kicking you rely heavily on the pedal kick itself. Unfortunately, as you have found out, on very narrow obstacles that just won't work. Try to use your body more. Preload your body/tire and think about jumping up almost more than jumping forward and just give a short stab at the pedals."2. "Your biggest problem is probably letting the brake off too early. Try to consciously delay letting the brake off until after your comfort point."I'm still working at it so I'm no pro, but letting the brake off a little later, and kicking just as hard, but with a shorter stroke has helped the most.I've been practicing this on a small concrete parking bumpers, and working on increasing the distance. Im getting better but not consistent yet.Thanks! I really appreciate that. I'll try it. Quote Link to comment Share on other sites More sharing options...
