zoster Posted August 8, 2008 Report Share Posted August 8, 2008 Hi!i have a custom mielec 24" frame, which is ok as it is, but it might have a slightly better geometry with a shorter fork. Does any of you guys know if a mod fork can take a 24" wheel?thanks! Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted August 8, 2008 Report Share Posted August 8, 2008 i was at my Girlfriends house once and my wheel was f**ked so i put her sisters wheel ("24, cheap wheel and tyre ) On my Forks (Lites) And it rubbed a little.Some forks will be longer though i'd imagine but I wouldn't think it's practical compared to just buying "26 forks Quote Link to comment Share on other sites More sharing options...
Muel Posted August 8, 2008 Report Share Posted August 8, 2008 I've got Onza T-Pro forks in my 24, they're sweet! I use a skinny tyre though, but theres still 20mm+ of clearance all round the tyre. Quote Link to comment Share on other sites More sharing options...
RossMcd Posted August 8, 2008 Report Share Posted August 8, 2008 Toxsin or Onza forks will work! I had a 26" wheel in my toxsin forks and it rubbed when the tyre was pumped up but 24 inch will probably work well! Quote Link to comment Share on other sites More sharing options...
JonMack Posted August 8, 2008 Report Share Posted August 8, 2008 Get Inspired forks? Dunno if they're available yet, but Rowan runs them I think Quote Link to comment Share on other sites More sharing options...
HarshRider Posted August 9, 2008 Report Share Posted August 9, 2008 it may or may not work.i wouldn't however go for shorter forks for a 24" or 26" for that matter.a lower front end would make the front harder to pull up, i would have thought it would be better to have a higher front end on a 24"?people with mods could measure 4" from there front tires and see if there would be enough room for a 24" wheel?i don't have a mod so i cant Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted August 9, 2008 Report Share Posted August 9, 2008 it may or may not work.i wouldn't however go for shorter forks for a 24" or 26" for that matter.a lower front end would make the front harder to pull up, i would have thought it would be better to have a higher front end on a 24"?people with mods could measure 2" from there front tires and see if there would be enough room for a 24" wheel?i don't have a mod so i cant Quote Link to comment Share on other sites More sharing options...
HarshRider Posted August 9, 2008 Report Share Posted August 9, 2008 haha cant believe i made such a stupid mistake, thanks for correcting me. i should be able to do basic maths Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted August 9, 2008 Report Share Posted August 9, 2008 haha cant believe i made such a stupid mistake, thanks for correcting me. i should be able to do basic maths I only know because someone corrected me on it a while back Quote Link to comment Share on other sites More sharing options...
Tom_ Posted August 9, 2008 Report Share Posted August 9, 2008 Noobz I dunno, most people try to get high front ends on there 24's normally with loadsa stackers and riser bars, I know the fork length will effect other things like H.A but I recon that a 26" fork would be best, or as previously mentioned wait for the inspireds. Quote Link to comment Share on other sites More sharing options...
cai Posted August 12, 2008 Report Share Posted August 12, 2008 Does any of you guys know if a mod fork can take a 24" wheel?I use 20" Ashton Justice forks on my 26" Koxx Levelboss - works a treat Quote Link to comment Share on other sites More sharing options...
