What Is Modulation?
modulation basically means rolling with the brake slightly on, some brakes are to grippy and just lock straight away so they havent got much modulation, but some brake arent grabby and you can feather them so the brake is gently on which usually helps with front wheel moves etc which is why we hear so much about it in trials :)
use a dictonary or the random small question thread.
brake pads with modulation are pads that will slow the bike down without locking the wheel but also have the ability to lock the wheel when required by the rider applying more pressur to the lever. for example a disk brake has modulation but a magura with a grind ans say plazma\tic pads doesnt have modulation
In braking terms,
Modulation mainly involves the bite of the brake,
It means that you can roll on either wheel without being instantly stopped.
Rim brakes tend to have a lot of bite, therefore, not a lot of modulation.
Disk brakes are usually a lot less bitey and offer a lot more modulation.
  DLB said:
Modulation - the act of modifying or adjusting according to due measure and proportion.
i.e. Effort in at the brake lever gives a noticable progressive response in braking, not just an on/off effect. :)
Dan.
wow thats a very good way of describing it. in my oppinion there is no better way possible of describing it.
