16 years later Posted August 5, 2008 Report Share Posted August 5, 2008 (edited) Ok I’m not too much of a basher. I tend to do smaller tech stuff. I want a rim that holds a grind reasonably well and was wondering which one you would go for. I am swaying towards the trialtech. Or would you go for some thing different all together.Edit poll working Edited August 5, 2008 by 15 years later Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted August 5, 2008 Report Share Posted August 5, 2008 If you're not a huge rider and don't bash your rim,The lightest rim you can fine should do, although that may not hold a grind.The TrialTech is certainly the lightest, not too sure about the grind holding capabilities Quote Link to comment Share on other sites More sharing options...
Z o o !! Posted August 5, 2008 Report Share Posted August 5, 2008 If you're not a huge rider and don't bash your rim,The lightest rim you can fine should do, although that may not hold a grind.The TrialTech is certainly the lightest, not too sure about the grind holding capabilities Quote Link to comment Share on other sites More sharing options...
Muel Posted August 5, 2008 Report Share Posted August 5, 2008 Try-Alls are pretty shite for holding grinds, Echo holds them best but is also the heaviest.You could always modify an Echo to make it lighter? Quote Link to comment Share on other sites More sharing options...
BenLeacock™ Posted August 5, 2008 Report Share Posted August 5, 2008 Try-Alls are pretty shite for holding grinds, Echo holds them best but is also the heaviest.You could always modify an Echo to make it lighter?My tryall held a grind really well :| Quote Link to comment Share on other sites More sharing options...
Muel Posted August 5, 2008 Report Share Posted August 5, 2008 Mine was awful! I had Rock blues though, maybe they ripped through the grind faster than most pads. Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted August 5, 2008 Report Share Posted August 5, 2008 dx32/ronnie hold grinds but are pretty thin, tryall/viz/trial tech/revel are all the same and dont really hold grinds but there good enough, echo holds grinds but are heavy :\ your choice really.Matx Quote Link to comment Share on other sites More sharing options...
