King Headset Loose
NoValidTitle
So I finally got my echo urban forks in the mail. I got the bottom bearing race on fine, slid the fork up through the frame but when put the top cap on and tap it down it will only go so far and won't snug up to the headset. Like if I pick up the frame so the weight comes off of the fork I can see it move, also just grabbing the steerer tube and moving it I can feel a little wobble. Now I've never owned a King headset but this just doesn't seem normal, any tips?
It sounds as though the steerer is too long on the forks, causing the top cap to bottom out before the headset is tight
Ideally you want the steerer to end about 3-5mm below the top of your stem to leave room to tighten things up
Try adding in an extra spacer and tightening it up - if it works then it'll more than likely be that, if not then we'll have to look for another explanation!
