Rear Tube
Reinis.
So, what tubes do you use for the rear? DH or some lighter? Recently I've been having some flats, so i'm thinking of a DH tube maybe. But maybe it's just because my rear tire is quite old. Have you ever flatted your DH tube? The difference in weight between DH and other tubes is noticeable?
I use a 1.95-2.125 tube on the rear, with a Creepy Crawler, and have never gotten a pinch, and i've had it at least a year. Just run a decent pressure (at least/around 20psi) and you'll be fine.
What rim are you running?
When he says decent pressure he is blatantly lieing when he says 20psi, hes running a good 35 in there when I rode it.
I run a Maxxis DH with between 20-25psi in it, still rim it ALOT but no punctures (touch wood)
Meh, f**k buying expensive tubes.
Go to Asda/Walmart and stock up on tubes for about £2 each, cheaper than a repair kit! They can last a suprisingly long time, and chances are they're made in the same factory as Maxxis.
I used to carry about 5 in my bag...get a blow out and just chuck a new one on...cheap and simple :)
On my mod I run a standard Kenda tube (130g) and a Creepy Crawler. Usually have about 15-20PSI in there, and I'm pretty light (60-65kg)
But I also backup what Anzo says, I have 2 spare Kenda tubes with me usually, £2.50 each from my LBS, and if I get a flat, just whack it out and replace it, beats fiddling around with a puncture repair kit for ages, I do that when I get home and have nothing to do.
Edited by Mark King
i find its more trouble to re set up my wheel with my mec, chain cog bash than to take the tube out of the tyre wheel still on and find it, put some glue on and a patch, put it back in and pump, and cheaper seeing as patches are like 15p each at lbs.
Matx
I use a Maxxis DH or FR tube (blue stripe). It weighs about 450g but it's worth it. Personally I find that a light rear tyre + thick tube work better than a heavy thick tyre and a thin tube.
Example:
- Tryall tyre + thin tube = flat after 15 minutes of riding and ~1,45kgs of rubber
- Schwalbe Big Betty + massive tube = no flats for weeks and ~1,3kgs of rubber
was using a standard specialized tube in a comp 24 for absolutly ages with no problems...
I used to run heavy duty downhill tubes (green ones i forget the make now) but i prefered the feel of a standard tube as it rebounded a little faster and was lighter.
I'm now running a standard (Halfords) tube in a koxx slick (rear) and have had one flat in three weeks hard riding, however, im now running 55 psi front and rear! lol
Hutchinson Green?
I use a front tube (20" front tube in a 19" tyre), haven't flatted in near 2 years. For me, DH tubes are completely overkill, but for street riders who run super low pressures and rim out a lot I guess they can be really useful. Just a shame they make your bike ride like it's in custard :(
I currently run some maxxis tubes from Mr Tart.
However i am trying to lighten things up substantially on my new bike and was wondering if there are some super light tubes available in 20" that would do the job???
Where/price would be very helpful if anyone knows
xxxxxx
tom
Hutchinson Green?
Good work Adam first try!! lol
xxxxxx
tom
KHE Flatland
84g
Pijin.com
http://www.pijin.co.uk/tubes/kheTwiggy.jsp
11.7 :$ and it feels a bit hard!
