cheesy Posted July 21, 2008 Report Share Posted July 21, 2008 Hey i will be getting a new hub sometime tomorrow that my father is buying me (woop woop) its 36 engagement or more (nice sound to it though) and i was just asking it you could take tooth sprockets off it so i can will just run a 15 tooth sprocket on it.If so would could i do it without hurting it as much lol.Thanks.....Cheesy.... Quote Link to comment Share on other sites More sharing options...
Tomm Posted July 22, 2008 Report Share Posted July 22, 2008 Are you English? What?What hub do you intend to buy? Just because it has 36 engagements doesn't mean it's going to be good for trials... Quote Link to comment Share on other sites More sharing options...
totaltrials Posted July 22, 2008 Report Share Posted July 22, 2008 I'm confused what you mean.What hub is it? When you say "gear hub" do you mean a rohloff speed hub? Or a Shimano Alfine etc.Secondly, if you do mean one of those hubs, why would you use one if you only want to run single speed.If you don't mean any of the above, what are you talking about. Just a normal hub? If so, are you talking about the cassette?You can split cassettes and use whatever gear you want from that cassette, but you will need spacers.If none of that helps, further explain what you mean. Quote Link to comment Share on other sites More sharing options...
psycholist Posted July 22, 2008 Report Share Posted July 22, 2008 If the 36 engagement hub is a shimano XT/XTR avoid it like the plague. The freehub may last (I have no reason to suspect the freehubs are that easy to break), but every current model XTR hub I now of that's seen mileage (2 for 2 so far) has had the axle snap in about a year with XC use only. Oversized thin walled axles, made from aluminium with threads cut into the outside of them aren't the best for fatigue life... The only Shimano hubs that survive trials use are the previous two incarnations of XTR with 16 engagements (so not great in use, but surprisingly reliable). Quote Link to comment Share on other sites More sharing options...
