Hope Hs33 Crossovers?
Ladd
Yeah, got my hope crossover today, and when i put it on and tighten it, the maggie callipers wont line up and i have to bend the cable, ? like it wont let it slide about like a maggie hose on barbed fittings, this means loads of stress on the crossover :( anyone else's do this?
All you need to do is loosen the shroud nut (the bit that tightens onto the fitting that goes into the cylinder), then you can twist the hose around to wherever you need (Y) Tightening the shroud nut back down will twist the hose or cylinder around 90 degrees, so the easiest way to get everything lined up is with the cylinders off the bike.
