Tyre Presure
what sort of presure do poeple use. I run bout 20-25psi no less.
having it any lower i think it feels almost............sluggish.
I use 2.35 back and front and usually run the front harder than the rear.
what do you guys run.
checkout Damon Watson's vid-7 when he does his sidehops, his rim virtually touches the ground during preload. think he runs a 2.5in kenda tyre at around 15psi.
I struggle with tyre pressure quite a bit. I like to have them soft for grip and "pump", but because i ride my low geared bike a long way to ride, and i like to spin a bit, i tend to have my tyre quite hard in comparison with other riders.
Its definately up to the individual riders... but i wouldnt recommend going for a real low pressure "<15 PSI" when just starting out as it will be quite a challenge.
Have fun trying to find a pressure that suits.
when the rim gets hit you will know. Low pressure is ok to start with, but watch out when you start to move to bigger drops, and moves. I thought I was perfect at 17 until I smashed the rim on a drop to a curb. Also real low pressure can increase the chance of tearing a tire.
says it all..... i wouldnt like to drop to a curb even with 40 psi..
i run less that 20 in back and about 25 in front...
Edited by Grant-Hundley
I think damon runs a maxxis on the back. and he usually runs about 30psi...
he is just a weighty b*****d.... and puts so much power through his bike
Im not sure what psi my tires were on my trials build but as im close to 13 stone i remember i had to run quite high pressure in the back compared to other riders. But thats just cos im a big ass guy lol, on my Kona Dj/trialsish lol bike i run both back and front at about 40ish but thats because moto digger tyres sidewalls are crap they collaps easily :)
