mad_gavo Posted July 12, 2008 Report Share Posted July 12, 2008 Just in the process of getting some new pads and a new rim on the back of my adamant A1 frame. Just wondering if there would be any benifit of buying and fitting a brake booster? As the brake has allways felt a little spongy Cheers Gavin Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted July 12, 2008 Report Share Posted July 12, 2008 unless you can see the frame flexing its probably your set up, what your brake is bled with and lever etc. it should be fine. the adamant frames dont need a booster. there quite solid. Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted July 12, 2008 Report Share Posted July 12, 2008 re-bleed your brake and set up new pads square, use some card or a 2p or something to set them up, even if you think it doesnt need a re-bleed do it anyway.if it still spongey get a booster.Matx Quote Link to comment Share on other sites More sharing options...
mad_gavo Posted July 12, 2008 Author Report Share Posted July 12, 2008 cant see it needing rebleeding as the maggie is only a month or two old Im getting new pads and rim so will make sure they are set up square from the offset. Just wondered what peoples veiw on having a booster were Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted July 12, 2008 Report Share Posted July 12, 2008 if its a new maggie and bled with oil its guna feel flexy/ spongy. because that is what blood does to it. Quote Link to comment Share on other sites More sharing options...
mad_gavo Posted July 12, 2008 Author Report Share Posted July 12, 2008 Water is what killed my last one so this one is staying as it came out the factory Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted July 12, 2008 Report Share Posted July 12, 2008 but oil suuuucks. meh. guess you will have to stick with the spongyness. and getting another booster will probs break your frame. apparently they need a small amount of flex. Quote Link to comment Share on other sites More sharing options...
mad_gavo Posted July 12, 2008 Author Report Share Posted July 12, 2008 Oh always used to run a booster on my old frame with no problem. Will see how it goes with the new pad and rim first Cheers for the help Quote Link to comment Share on other sites More sharing options...
Guest Posted July 12, 2008 Report Share Posted July 12, 2008 if its a new maggie and bled with oil its guna feel flexy/ spongy. because that is what blood does to it.I have never heard such utter shite in my life.You can achieve a solid feeling brake using oil. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted July 12, 2008 Report Share Posted July 12, 2008 Oil works fine, and out of the factory they're generally pretty well bledThere's no real reason for a brake to ever need rebleeding other than damage, unless you've had it apart at some point of course Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted July 12, 2008 Report Share Posted July 12, 2008 but oil suuuucks. meh. guess you will have to stick with the spongyness. and getting another booster will probs break your frame. apparently they need a small amount of flex.BOLLOCKSits air in the system that compresses, rebleed it Quote Link to comment Share on other sites More sharing options...
grant_hundley Posted July 12, 2008 Report Share Posted July 12, 2008 but oil suuuucks. meh. guess you will have to stick with the spongyness. and getting another booster will probs break your frame. apparently they need a small amount of flex.haha Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted July 12, 2008 Report Share Posted July 12, 2008 I found the A1 tend to flex quite a lot. even with a the built in booster! Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted July 12, 2008 Report Share Posted July 12, 2008 (edited) meh. iv always found blood to be more spongy than waterand iv seen people with cracks in their mounts from running a booster when it wasnt needed. Edited July 12, 2008 by rudirudirudirudirudi Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted July 12, 2008 Report Share Posted July 12, 2008 meh. iv always found blood to be more spongy than waterand iv seen people with cracks in their mounts from running a booster when it wasnt needed.my echo cracked. not because I run a booster, just because it 4 years oldmaybe your bleeds just suck Quote Link to comment Share on other sites More sharing options...
