Koxx Bloxx Browns
stunt man t
i recently bought some koxx browns pads,
because i heard they were good on a ground rim,
and my existing pads werent holding very good (N)
but look whats happened to them :o
has anybody else had this problem?
its happened on both side!
its like its torn it away from the backing
mine went like that, but after a very very long time. over a year....
heatsinks reds in cnc'd backings. youll be sorted for ages! or just dual disc..
as for the problem. how long you had the pads?
edit: ps, you need a deeper grind ;)
ive only had the pads about a month
Faulty batch/set then pal :). Unless you have SERIOUS issue's setting your brake up :P
well i dont think i have an issue setting my brakes up
check out the pic,
do they look badly set up to you?
actualy....
if you look at the pad and the backing,
dosnt it look like the pad aint on the backing properly?
i dont no, it just looks like it aint bin put on properly to me
what do you think?????
Edited by stunt man t
check out the pic,
actualy....
Yeah i deffinatly agree they arn't glued in properly, I was winding you up about setting your breake up :). Like i said, give the tarty boys a phone and explain exactly what has happnend, they'll probs ask you send the pads back and you'll get another set :)
check out the pic,
actualy....
My Greens were the same, No problems there though! and I got them NEW for £11.50. (the joys of Halfords)
