My Brake Doesn't Make Any Noise...
TrialZonn
Hello everybody.
I'm using Magura HS33 at the rear with a smooth rim and Adamant Pads.But when I use the brake, it doesn't make the common screaching sound...
The Wheel stops but I don't know if the max stopping power is achieved (because I know that the brake must make some noise)
Maybe I haven't set up the magura???
You may have found the holy grail of trials brake setups - a brake that locks the wheel properly but doesn't annoy non-trials riders around you by making noise... Try other people's brakes and see if you're getting the same hold though. Maguras with normal brake pads on a smooth rim are silent, but don't have the kind of savage wheel locking power needed to not get you killed landing big gaps to back wheel.
= disc brake :D
Afriad not, discs are shite.
Vee for the win woop
And also your +rest of forum isnt right you'd be suprised how many tools on here depend on having a brake that makes noise and even if it holds like fook they won't like it.
Wrong :P You always say discs are shit, who's have you been using?! Mine's f**king epic.
well im refering to rear disc as i run one on front. Ive used tarty adams and the ex tarty dave and a few lads ino. And the feel of it was so horrible.
Edited by basher
Well, Im in search of an awsome brake that is silent, Im fed up of making masses of noise when I want to slow down when riding too and fro places etc.
Tempted by dual disk, however I am convinced I will land on my rotor, Everyone says I wont But I land on the disk mounts on my pro 2 now and then and I know that because there scratched. Im not up for having to fork out 15quid every week or 2 for a new rotor :(
I'd be interested in trying dual Formula ORO's on a trials bike - their bite seems to be pretty fierce (Based on three sets I've tried on people's XC/DH bikes) - the ORO K18's are cheaper than Hopes too. The temptation to get a dual disk trials bike to try it out is strong - mostly because I occasionally ride my bike at weird hours of the night in built up areas and would rather not piss everyone around off by making noise...
thanks for the information.
My brake don't slip when I land on the rear wheel from a gap or curb...
I witnessed that it slips only if I make a fairly long jump from a pedalkick and then land the bike almost horizontial.I don't know if the brake was supposed to lock in this situation because the momentum created from the move is fairly big.
As for the disk brakes...My opinion is that a dual disk would have 100% lock but it would be heavier than a V or Magura Setup...
It's very interesting to see a trials bike with dual disk (I haven't seen one yet) but that means that you must have the proper frame too...
My solution for this problem is to have a noisy back brake and a quiet front brake, such as disc/hs33, which should give you a quiet front brake. Or an unground/untarred front hs33.
  • 2 weeks later...
My brake dosen´t make any noise and works just fine ,, something strange becouse i have the same setup at front and its to lauder ,, (dx 32 smoth grind , old style lx brakes , custom pads) ,, the secret , i think, are my custom pads ,, haha
I run blue rock pads ona grinded wheel on the rear and it works really well for me, if its having an off day i add a slight bit of tar!
I do know a few mates that have a good working brake thats also silent but not many but if it works fine!
Running a disc on the front can be helpfull but i prefer Magura.
Andy
