What Should I Get (im A Beginner)
Hi Joe,
By P2 do you mean the Specialized P2? If so i wouldnt reccommend it for trials as at is primarily a dirt jump/street bike, but could also be used for trials, although the suspension may cause a problem (increased weight and less connection/feeling with the ground). Also the frame is quite heavy (depends whether you have the cromo or alu one).
Not sure about the ZHI, as i have no personal experience of them, theres one for sale in AustraliaHERE Have a look and see what you think, the frames look pretty nice.
About wheel size, depends what youve ridden before if youre used to 26inch then stick with it, as the change would be very different. There are no real advantages to either.
20 inch
lighter, smaller, more flickerable, cheaper (only slightly), easier to learn
26 inch
more parts/frames to choose from, more practicle/useable (with a seatpost), easier to roll over objects.
I ride a 26 inch, and would highly reccommend it.
thanks for the info,
i've had mixed answers about what i should get and still dont completely know what to get.
i will use your info to the best i can.
yes i do mean Specialized p2, and its an alloy not cromo.
is there much difference in the geometry of the p2 compared to the 26"?
yeh i agree, i wouldnt use a p2 for trials, would be way to heavy and uncontrolable.
i started on a 20", was quite heavy but allowed me to get the basics down with ease.
of course the more money you have the lighter the bike you'll be able to have.
but yeh, p2 (N)
