mad max Posted July 8, 2008 Report Share Posted July 8, 2008 I have been riding my new build for about four months now and i am struggling with the new setup.( but still loving it) When i am on the bike i feel as though i am too far forward and struggle getting my ares over the back wheel, it feels like i can't stretch far enough back, but i just thought it was me getting used to a new bike. This weekend when i was out i tilted my bars back a little which has helped a lot. Do you think my stem is too long?. I have a Adamant A1(short) with a Echo hifi stem (130mmx15). I am 5ft 8 Advice would be great. Thanks. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted July 8, 2008 Report Share Posted July 8, 2008 Sounds like the stem could be (at least part of) the problem, and even if it's not it's cheap and easy to change that Assuming you're on the lower BB (newer version) A1, try and stick on something in the region of 110 x 10 or so, it should feel a fair bit better from the off (maybe a spacer or two to keep it at a decent height) Before you buy/borrow a new stem though, it may be worth rotating your bars back a touch. Should give a slightly 'streetier' feel, and aid manual/bunnyhop style moves too Quote Link to comment Share on other sites More sharing options...
mad max Posted July 9, 2008 Author Report Share Posted July 9, 2008 I have got the new one. thanks for the advice i will try a shorter stem. Hopfully my arms will feel longer than 2ft Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted July 10, 2008 Report Share Posted July 10, 2008 If possible, don't forget to try adding headset spacers underneath your current stem too. Might feel a bit better Quote Link to comment Share on other sites More sharing options...
