czarbikes Posted July 2, 2008 Report Share Posted July 2, 2008 Bro is having problems with his zhi zm1b snail cams not working What snail cams will work He is using a echo disc hub and a zhi zm1b frame please thanks Jamie Quote Link to comment Share on other sites More sharing options...
Skoze Posted July 2, 2008 Report Share Posted July 2, 2008 In what way aren't they working? Quote Link to comment Share on other sites More sharing options...
COCKY Posted July 2, 2008 Report Share Posted July 2, 2008 A pair of echo cams or monty cams fit Quote Link to comment Share on other sites More sharing options...
czarbikes Posted July 2, 2008 Author Report Share Posted July 2, 2008 (edited) In what way aren't they working? They won't fit the hub jamie A pair of echo cams or monty cams fit no they don't got both of them the echo ones fit the hub but don't tensoin the chain enough Edited July 2, 2008 by czarbikes Quote Link to comment Share on other sites More sharing options...
COCKY Posted July 2, 2008 Report Share Posted July 2, 2008 (edited) or you could drill the hole bigger in the cams your running now have you tried that? Edited July 2, 2008 by COCKY Quote Link to comment Share on other sites More sharing options...
czarbikes Posted July 2, 2008 Author Report Share Posted July 2, 2008 yeah get a pair of monty or echo dent know if you can just buy the echo ones or you could drill the hole bigger in the cams your running now have you tried that? there not big enough they don't tensoin the chain enough Quote Link to comment Share on other sites More sharing options...
Barbara Logan-Price Posted July 2, 2008 Report Share Posted July 2, 2008 there not big enough they don't tensoin the chain enough well maybe shorten the chain Quote Link to comment Share on other sites More sharing options...
COCKY Posted July 2, 2008 Report Share Posted July 2, 2008 (edited) unno the bolt that your snail cams hit if you was to put in a bit longer bolt and a few washers that will give you an extra 4-5 mm then your cams should work Edited July 2, 2008 by COCKY Quote Link to comment Share on other sites More sharing options...
czarbikes Posted July 2, 2008 Author Report Share Posted July 2, 2008 well maybe shorten the chain tried that al what snail cams you use al Quote Link to comment Share on other sites More sharing options...
Barbara Logan-Price Posted July 2, 2008 Report Share Posted July 2, 2008 zhi Quote Link to comment Share on other sites More sharing options...
czarbikes Posted July 2, 2008 Author Report Share Posted July 2, 2008 zhi where can you get them from Quote Link to comment Share on other sites More sharing options...
Ben H! Posted July 2, 2008 Report Share Posted July 2, 2008 where can you get them from here jamie http://trials-uk.co.uk/product.aspx?productid=1345 Quote Link to comment Share on other sites More sharing options...
