HarshRider Posted July 1, 2008 Report Share Posted July 1, 2008 hey i have just been trying to sort out my old magura on me bike, its the old style hs33 basically the master cylinder in the lever keeps getting stuck, i striped the whole lever down and cleaned out all the grime and tried it again but still the same result. it was last bleed with water using the bath lol, it has also been sat on my bike not used for around a year, perhaps it froze in the winter and has mucked up. would it help if i got it bleed with oil with the proper bleed kit? or is it likely that the master cylinder is non usable? any help would be appricated (sp) thank you Quote Link to comment Share on other sites More sharing options...
Daborn Meister Posted July 1, 2008 Report Share Posted July 1, 2008 Have u done up the lever clamp bolt to tight? Try loosening it. Joe Quote Link to comment Share on other sites More sharing options...
JT! Posted July 1, 2008 Report Share Posted July 1, 2008 I had the exact same problem. I personally think it might have something to do with bleeding with water. As the piston isn't getting lubed up anymore. Anyway, i just bought a new leaver. Quote Link to comment Share on other sites More sharing options...
HarshRider Posted July 1, 2008 Author Report Share Posted July 1, 2008 nope, it still does it when there is no lever on the body. its the piston inside the lever that gets stuck, it returns back to normal but can take up to a minuet to do so which means when its on my bike the wheel will get locked for ages I had the exact same problem. I personally think it might have something to do with bleeding with water. As the piston isn't getting lubed up anymore. Anyway, i just bought a new leaver. when it happened to you did you try bleeding it with oil afterwards? also would putting a bit of grease on the piston help or would it mess up the piston, and cause it to leak? Quote Link to comment Share on other sites More sharing options...
JT! Posted July 1, 2008 Report Share Posted July 1, 2008 when it happened to you did you try bleeding it with oil afterwards? also would putting a bit of grease on the piston help or would it mess up the piston, and cause it to leak? I tired everything and just gave up. I'll find the topic that i make for you. http://www.trials-forum.co.uk/forum/index....=103252&hl= Quote Link to comment Share on other sites More sharing options...
HarshRider Posted July 2, 2008 Author Report Share Posted July 2, 2008 cheers for that, ill give it a go tomorrow! wheres the best place to go for replacement seals? is it just a job of going to a plumbing merchant and buying some that fit or would i need special magura ones, cheers Quote Link to comment Share on other sites More sharing options...
stpatr3k Posted July 3, 2008 Report Share Posted July 3, 2008 I've encountered this problem with an HS-22 bled with water. The piston "grew", its wasn't the seal on the piston but the piston itself ... I just got a 1000 & 300 sand paper, sanded the piston with the rough 300 first then finished it off with the 1000, re-bled it and it was fine. Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted July 3, 2008 Report Share Posted July 3, 2008 i find that when your lever gets like that the only thing to do is use some realy realy thick oil inside of the brake to lube it up . Quote Link to comment Share on other sites More sharing options...
Concussion Posted July 3, 2008 Report Share Posted July 3, 2008 Same kinda thing happened to me a while back... After messing around with it for ages and having no joy, I noticed the piston had a really slight groove down one side, I lined it up with the `wield` on the lever body where the two halves are joined and it worked fine. (god knows how it got twisted by it's self?)Prior to that the piston would get stuck really bad, but after lining things up it was smooth as anything! Sounds like bullshit I know, but it worked! Quote Link to comment Share on other sites More sharing options...
HarshRider Posted July 4, 2008 Author Report Share Posted July 4, 2008 sorted and working again on water. only problem is my tpa totally fell apart so i have to make one from scratch now. what i did in the end was get a large drill bit and wrapped wire wool around, carefully took it inside the cylinder and piston. put alot of oil in the cylinder and put it back together. good as new, apart from the tpa of course. Quote Link to comment Share on other sites More sharing options...
matt rushton Posted July 6, 2008 Report Share Posted July 6, 2008 I just sprayed WD40 into the cylinder sorted it out. Quote Link to comment Share on other sites More sharing options...
