G-baby158 Posted June 30, 2008 Report Share Posted June 30, 2008 Hi, i have a zona zip and need to know how hard it would be to spray it, my uncle finks its going to be hard but i want to know your opinion, i know some one i think his name is Dan has sprayed his loads of times. And how would i take the bash plate holders off the frame and make the hole where the seat post would go bigger (if you get what i mean). Quote Link to comment Share on other sites More sharing options...
ogre Posted June 30, 2008 Report Share Posted June 30, 2008 Hi, i have a zona zip and need to know how hard it would be to spray it, my uncle finks its going to be hard but i want to know your opinion, i know some one i think his name is Dan has sprayed his loads of times. And how would i take the bash plate holders off the frame and make the hole where the seat post would go bigger (if you get what i mean). you can't take the plate holders off, there welded on put some tape over the threads to protect them from paint + go nuts. why would you want to make the seat triangle bit bigger? use an angle grinder or a hacksaw or dremel etc. as for painting you'll need to: strip the whole thing down to frame with bb+headset + tape over threads. nitromorse off any existing paint. lightly sand the frame to make pain stick better. prime it [base coat of paint in black or white, depending on how bright you want the finish to be] spray it your colour laquer if you feel the need. if your hardcore you can look up making a heater for your frame to really set the paint. Quote Link to comment Share on other sites More sharing options...
