Hi I Need Help
FEELEY-ROB
If your talking about the red adjuster on the brakes then it depends what model you have, if you have the older model when the adjuster is on the top of the leaver there is a bodge which can be found some where in the trials chat section, if you have the new model where it sits in the middle of the leaver then you will have to buy a new tpa which can be found on www.tartybikes.co.uk
how much are they because the site is underconstruction?
