sideburns(dnt ask) Posted June 26, 2008 Report Share Posted June 26, 2008 Hi Guys, im currently in the process of buying a monty 221ti but as i'm unsure on the cost off maintaining the disc brakes. So if worst comes to worst will i be able to use magura braze on mounts as i've heard brazing aluminium dosn't work. cheers for any input. peace Quote Link to comment Share on other sites More sharing options...
forteh Posted June 26, 2008 Report Share Posted June 26, 2008 Braze on mounts will be steel and as you guessed you cant braze steel to aluminium No reason why you cant get a decent frame builder to weld some aluminium mounts on though, I would want to be particular about the treatment after welding as its basically catastrophic brake failure on that huge gap if they break Quote Link to comment Share on other sites More sharing options...
